Timmetje wrote:
Thanks a lot for the help sciguy and rruff, I will definitely try your method again. One final question, I was wondering how you clean the chain before re-waxing?
Although very clean, there is always some dirt/road debris sticking to the chain (at least in my experience). I tried to clean this off using a brush and some water, but it did not clear all. You can see the dirt in the wax after waxing; it sinks to the bottom leaving a grey layer in the wax. I guess because it sinks to the bottom it is not that problematic. However the wax will inevitably become dirtier. Do you have a special cleaning ritual before re-waxing as well?
I'm using high test isopropyl alcohol on paper towels to wipe the chain down before relubing. I keep wiping until the discoloration pretty much stops coming off. No water needed or wanted for cleaning. If you pop the solidified wax puck out of your heating container you can scrape off the thin dirty layer at the bottom to keep your lube cleaner. The nasty stuff will sink to the very bottom so you only need to scrape off a very thin layer.
Hugh
Genetics load the gun, lifestyle pulls the trigger.
