mvenneta wrote:
If you want to be a successful roadie. .. you might consider working on building your <5 min power.
I had the same types of questions when I started RR this year.
I had always trained like a triathlete which is steady power. A strong roadie can do surge, steady, surge, steady
Doesn't answer your question directly, but there is hope that with the right training you can improve the short bursts!
over/under work. if you can't active recover you are doomed in RR and crits. your body needs to learn what it feels like to recover at 85%-90% of FTP after doing 135-150% for a short duration right before. The lower cats the surging is certainly worse because EVERYTHING that moves off the front is the breakaway that is going to get away, or at least thats how people treat it. All it does it cause the pack to super surge to close the gap and then it goes back to the giant swarm until someone does it again.
I remember my first RR in cat5. 88km relatively flat, was around farm fields so you could literally see almost the entire way around the course from any point on it. 600m or so into the race two guys try and take off. Some idiot from mid-pack is screaming "THATS THE BREAK GET IT!!". All of a sudden im pushing 600w trying to keep up with the massive acceleration for 10s to bring these two idiots back.
Not that it doesn't happen in cat1/2/3, but its certainly a little more strategic in nature, and people are smart enough to let two guys go off the front and burn themselves out.
