spudone wrote:
ericmulk wrote:
You absolutely have to pull hard to get any sort of speed in the water.But not downward.
Focus needs to be on keeping the elbow near the waterline throughout the stroke. It'll might feel weaker at first until the form is ingrained.
I agree, but you gotta still take this with a realistic grain of salt - even if OP pulled dead straight back with perfect form, his pull power and turnover rate is so slow that he would be at BEST 1:50/100, and that's with perfect body position and a perfect EVF. The biggest issue for his lack of speed is pull power, not pull angle.
Again, this does NOT mean I'm recommending he just ignore the technique and go hog wild on power, sacrificing technique. He should keep a mind on improving that technique while simultaneously doing workouts that improve power (along with technique). But it's very important to be realistic about why he's not fast - the single most dominant factor is lack of fitness/power. Changing pull angles and body position will help, but will not suddenly turn his 2:00/100 into a 1:30/100 swimmer. (Whereas I and many swimmers here could take his very same technique flaws and still easily come in under 1:40/100, if not sub 1:30/100.)
