sciguy wrote:
woof wrote:
Ok. - I am week from 11 o-clock to 1 o-clock on both legs...
FYI the research shows that those who in their natural pedaling style apply the most torque at 12 and 6 o'clock are the least efficient! So if you really want to decrease your efficiency keep working hard on those sectors.
"ABSTRACT The purpose of this study was to determine whether there is a causal relationship between pedalling "circularity" and cycling efficiency. Eleven trained cyclists were studied during submaximal cycling. Variables recorded included gross and delta efficiency and the ratio of minimum to peak torque during a duty cycle. Participants also completed a questionnaire about their training history. The most notable results were as follows: gross efficiency (r = -0.72, P < 0.05 at 250 W) was inversely correlated with the ratio of minimum to peak torque, particularly at higher work rates. There was a highly significant inverse correlation between delta efficiency and average minimum torque at 200 W (r = -0.76, P < 0.01). Cycling experience was positively correlated with delta efficiency and gross efficiency, although experience and the ratio of minimum to peak torque were not related. These results show that variations in pedalling technique may account for a large proportion of the variation in efficiency in trained cyclists. However, it is also possible that some underlying physiological factor influences both. Finally, it appears that experience positively influences efficiency, although the mechanism by which this occurs remains unclear.
Whole-body efficiency is negatively correlated with minimum torque per duty cycle in trained cyclists (PDF Download Available). Available from: http://www.researchgate.net/..._in_trained_cyclists [accessed Sep 1, 2015]."
Hugh
If research shows that smooth pedaling is overrated, why do most pro cyclists have a silky stroke? Remember that the studies usually deal with short-duration power output where pushing down as hard as possible, with the resulting ragged pedaling action, is more effective. However, this masher style is fatiguing over several hours. As a result, good riders automatically smooth their pedaling to increase comfort and efficiency over the long haul. Elite riders can do both -- produce maximum power for short periods as well as pedal elegantly for hours.
