harts wrote:
Nate I have been liaising with Wahoo about the different in measured power between the Kickr and my power2max. They have outlined that firmware has been developed that allows an external power meter to control the kickr. They mentioned that this firmware is being developed in partnership with external partners (such as trainer road) to implement in their apps. Is this something that is being worked up??
I got the same message from a technician trying to help me. No timeline was given.
Until then I have settled into a particular process.
I use the Kickr to control TrainerRoad in ERG and allow that data to be uploaded to TR, which also passes the same data out to other web based sites like Strava. My FTP in TrainerRoad has been bumped up 11 watts based on several tests between the Kickr and a Quarq.
Use a Garmin Edge to record the power from a Quarq ELSA and upload it to WKO+ and Golden Cheetah. The data in WKO is what I track for training trends and feel comfortable knowing that the data is good. My data shown at TrainerRoad and Strava is inflated for those in my social circle looking. So if you happen to see it I am actually 11 to 13 watts less in performance.
I have to remember to disable Garmin Express when I connect the Edge so it does not duplicate the data on Strava, Connect and TrainingPeaks since that data is synced from TrainerRoad using Tapiriik. I've had to go back through my training activities and delete some of the duplicates because I forget at times to disable Express.
It will be nice when this gets sorted out with the offset value when and if Wahoo gets it sorted out so that I can simply record the data to TrainerRoad and eliminate the step with the Garmin Edge.
