Bike Shops
Coaches
Fitters
Race Calendar
Running Stores
Store
Stack & Reach
Training Log
Triathlon Clubs
We Noticed
MAIN INDEX
RULES & LEGEND
LOG IN
Slowtwitch Forums
Torque Wrenches?
Tri
Classifieds
Lavender
Jobs
Womens
Notices
Print Thread
JTolandTRI
Jan 28, 13 8:42
Post #1 of 23
(955 views)
Torque Wrenches?
Quote
Reply
Recommendations? Good/bad? Differences between manufacturers?
Thanks!
Jack Toland
Sponsors:
Rudy Project
Blog
Twitter @JTolandTRI
endorphin
Jan 28, 13 8:54
Post #2 of 23
(934 views)
Re: Torque Wrenches? [JTolandTRI]
In reply to
Quote
Reply
Go for beam style instead of click style. They are cheaper and more reliable. Click style wreches, especially cheaper ones, can require periodic calibration, or you risk over/under-torquing parts.
As for manufactures, I like my Park Tool TW-1 (high torque) and TW-2 (low torque) beam style wrenches. But really any hardware store version is fine - no need to be cycling specific. It can be a tricky to find one for lower torque spec (<6 Nm).
Blog
Twitter
key4871
Jan 28, 13 8:57
Post #3 of 23
(922 views)
Re: Torque Wrenches? [endorphin]
In reply to
Quote
Reply
X2 on beam style. I also have the Park's, and my local shop uses the beam style also.
grosso27
Jan 28, 13 8:58
Post #4 of 23
(918 views)
In reply to
Quote
Reply
I am a huge nerd for high end & well built tools, and I can vouch for the Effetto Mariposa torque wrench being one of my favorite tools of all time. Hell, it's even made its way into my jersey pockets on some rides, pretty much just because I can :)
At the very least, go click style, make sure you reset to zero after use, and don't buy one from harbor freight.
Wattie Ink Elite Team
K-Swiss
Scott
PowerBar
BlueSeventy
FuelBelt
Kask Helmets
ISM Saddles
Speedfil
Reynolds
Rev3
owtbac86
Jan 28, 13 8:58
Post #5 of 23
(919 views)
In reply to
Quote
Reply
No problem here with click style - use the Performance brand one.
Easy to travel with, the only downside for me has been that the setting isn't high enough for Quarq install.
PSJoyce
Jan 28, 13 9:21
Post #6 of 23
(889 views)
Re: Torque Wrenches? [grosso27]
In reply to
Quote
Reply
I'm with you on the Effetto Mariposa torque wrench -- my favorite tool, too
jaretj
Jan 28, 13 9:42
Post #7 of 23
(855 views)
In reply to
Quote
Reply
Snap-on
CDI
Proto
Good - accurate
Bad - expensive
Good - My work has a zillion of them in all different ranges
Bad - I get lazy and forget to bring them back to work
Kscycler
Jan 28, 13 10:09
Post #8 of 23
(812 views)
In reply to
Quote
Reply
X2 on the Effetto Mariposa. If you fly with your bike, having a torque wrench along is almost mandatory. The Effeto is less than 7" long, so TSA won't confiscate it. I've donated 2 torque wrenches in the past 4 trips, and now only fly with the Effeto.
hiro11
Jan 28, 13 11:41
Post #9 of 23
(740 views)
Re: Torque Wrenches? [Kscycler]
In reply to
Quote
Reply
Answer #1: you really don't need a torque wrench for bike maintenance.
Answer #2: I also have the Forte brand $90 metric / click-type one. Seems pretty good for the money. Remember to set the dial to 0 for storage.
perullo
Jan 28, 13 11:59
Post #10 of 23
(703 views)
In reply to
Quote
Reply
My Mariposa has burned me a few times. It took me many incidents before I stopped assuming it was user error, but the most recent spat a few weeks ago really convinced me. In short, it just doesn't click sometimes. I crushed a basebar like that, stripped a few screws and, most recently, cracked open the threaded boss on BOTH of my new sram red brake calipers. Not cool. Most cable tension screws are made to strip before the item in question cracks/breaks - which is awesome - but sometimes that just isn't feasible. Such is the case on those brakes. After I did it to the front, I was a bit concerned..double checked the torque setting, backed it all the way off, reset it... concluded I would have to go back to my old brake up front... did some more work, and then set the back brake.. POW. I had it set to 5nm... and I'd bet it cracked around 10 - so it's not like I had to be completely brutal to do it.
At this point I'm going to stick to feel a LOT more. I'll just be making stuff tight. I'll set the wrench too, but I'll let the pop surprise me, and otherwise be expecting to use feel.
A little dial model the size of the mariposa would be cool.
Kscycler
Jan 28, 13 12:10
Post #11 of 23
(688 views)
Re: Torque Wrenches? [perullo]
In reply to
Quote
Reply
I agree that's not cool, and I'd be asking Effeto to make it right. Since it's a mechanical device, it's not like it can decide to click or not. Something is (apparently) wrong inside, so it needs to be looked at. Right or wrong, I walk my torque up in steps so that I don't try to go to desired value on the first tightening. That way I know things are working right before I get too tight.
But if you read above,
you don't really need a torque wrench for bike maintenance.
perullo
Jan 28, 13 12:18
Post #12 of 23
(676 views)
In reply to
Quote
Reply
smart idea - walking it up from 2nm etc.
Kscycler
Jan 28, 13 12:42
Post #13 of 23
(656 views)
In reply to
Quote
Reply
I hear these guys are pretty responsive about supporting their products. There's also a link to register your wrench and get it (re)calibrated...
http://www.cantitoeroad.com/giustaforza-ii-216
lightheir
Jan 28, 13 13:06
Post #14 of 23
(637 views)
In reply to
Quote
Reply
Do you need 2 different wrenches for hi/lo, or can you buy one? These torque wrenches are typically a bit pricey!
endorphin
Jan 28, 13 13:21
Post #15 of 23
(621 views)
Re: Torque Wrenches? [lightheir]
In reply to
Quote
Reply
You need both to do every bolt on a bike. The TW-1 does 0-7 Nm and the TW-2 does 0-70 Nm. You wouldn't have enough precision using the TW-2 for low torque bolts since the increments on the scale are too large. The TW-1 couldn't do high torque applications like the cassette lock ring or threaded BB.
In practice, I think you could get away with just having a low torque wrench. It's really only the low torque bolts (stems, steerer tube, brakes, seat post, derailleurs, etc.) where accuracy is critical. Plus or minus a few Nm won't make or break your BB but it could certainly cause your handlebars to crack or slip.
And properly torquing bolts is more important for carbon parts than for aluminum parts. IME, aluminum is a lot more forgiving, at least when it comes to over-torquing.
Blog
Twitter
corneliused
Jan 28, 13 13:33
Post #16 of 23
(596 views)
In reply to
Quote
Reply
I'm comfortable with a cheap harbor freight click style wrench for the larger bolts on my bike. Pretty much just bb and crank arms though. I'd recommend something better than what harbor freight offers for small bolts and lightweight parts, especially if you have to ask.
tigermilk
Jan 28, 13 13:41
Post #17 of 23
(585 views)
In reply to
Quote
Reply
And having that torque wrench in hand saves you how? A torque wrench is but just 1 thing that can go wrong. The end user (and for that matter the OEM) has no idea about running torque, nut factors, torque-preload variability, ... All these things matter, and having a torque wrench is false protection unless you know the others.
BookemDanO
Jan 28, 13 13:48
Post #18 of 23
(572 views)
In reply to
Quote
Reply
I use a Craftman Professional - got one with low torque and metric (they will all do Nm, but the standard ones can be harder to read). May need to order it.
Get a nice set or two of metric hex heads - short/long and/or ball/straight
Click v. beam style -- whatever. Wind down to zero for storage.
If I'm going for 5 Nm, I'll set it for 4 initially then finish at 5
mcycle
Jan 28, 13 18:23
Post #19 of 23
(450 views)
In reply to
Quote
Reply
http://www.slowtwitch.com/...particular__364.html
http://www.probikekit.com/...HAjLUCFQyDnQod_DsAVQ
JTolandTRI
Jan 28, 13 18:41
Post #20 of 23
(423 views)
Re: Torque Wrenches? [mcycle]
In reply to
Quote
Reply
Thanks everyone for the replies!
Looks like the Giustaforza is the wrench to get for travelling and on the go maintenance.
Jack Toland
Sponsors:
Rudy Project
Blog
Twitter @JTolandTRI
mcycle
Jan 28, 13 18:54
Post #21 of 23
(406 views)
In reply to
Quote
Reply
I purchased it based on Dan's review. No regrets at all.
tri_yoda
Jan 28, 13 19:39
Post #22 of 23
(372 views)
In reply to
Quote
Reply
I have a Park tool beam style. Pretty inexpensive, I can't vouch for its accuracy, but I have never had a problem with a loose bottom bracket or crankset, or getting it off, so the torque must be okay.
lightheir
Jan 28, 13 19:53
Post #23 of 23
(359 views)
In reply to
Quote
Reply
mcycle wrote:
http://www.slowtwitch.com/Tech/Torque_wrenches_and_one_in_particular__364.html
Man, $142 for a wrench is a lotta money. Just sayin'.
Print Thread
this forum
this category
all forums
All words
Any words
Whole Phrase
The New Specialized Wind Tunnel
Will this be a game changer for Specialized, in both sales and product design, or will it not move the sales and design needle versus those in Specialized's competitive set?
Yes, Game Changer
Minor move forward
Won't budge the needle
