Some random wind tunnel observations and datapoints
Thanks to the folks at Faster, I got a few insights on positioning and gear. A few big lessons (which may or may not apply to anyone else):
1) My seat was too low. I guess I should have listened to Dan Empfield. Maybe some of you remember this thread:
Slowman says Jens' seat is too LOW...
In the intervening decade, I reverted to my old, bad ways and lowered it again. Aaron suggested raising it 2 cm. Hmm. Same as Dan.
2) More drop isn't always better. How your body achieves that drop matters. I went from ~14cm drop to ~10 and ended up with less drag. That's really big, because for me, 4cm less drop also means ~15 watts more power output.
3) Helmets really, really matter. In my case, the difference between two aero helmets was over 100 grams of drag.
4) Skinsuit matters. A slightly baggy one vs. better fitting swiftspin was worth around 70 grams.
5) Q-factor matters, though not as much as hoped. I switched from ~160 to ~130, which saved ~50 grams at 0 deg; 34 grams at 5 deg; but actually increased drag 19 grams at 10 deg. Maybe some smarter folks than myself can interpret that.
Re: Some random wind tunnel observations and datapoints [jens] [ In reply to ]
Jens, Thank you for posting this. I really enjoy your posts and have gotten a lot out of them. Much appreciated.
One thing I'm starting to appreciate is just how individual aerodynamics is. For me, the delta between my slowest helmet and my fastest helmet was 27 grams and the majority of my helmets were within 10 grams of each other. My Virklon sleeved tri suit was actually *slower* than my sleeveless Kiwami tri suit by 25 grams. Sorcery I tell you!
Just a random thought, the people at Faster, A2, etc. should consider tracking body morphology to see if there are any trends.
Disclaimer: I often promise photos fully intending to provide them and then get distracted. Sorry in advance :)
Great post, thanks for sharing! Can you expand on the aero helmet testing? Did you test head down and head up positions? Did you only test two helmets, or was that the delta between best and worst?
Also, I'm curious how they determine increased power output from positional changes. Do you just do a max effort in each position?
Re: Some random wind tunnel observations and datapoints [chrisgrigsby] [ In reply to ]
I only tested two helmets and just in the position I would actually ride in -- low, but eyes up the road. I suspect helmets are highly individual. I previously compared notes with an Olympian who had tested the same two helmets as me and had precisely the opposite results(!).
The drop/power differences are based on my own long-term experience. I'm probably an an extreme example in this regard. Even with the clown cranks, going from a road position to 14cm drop decreases power over 30 watts.
Re: Some random wind tunnel observations and datapoints [GreenPlease] [ In reply to ]
The problem with body morphology is that it's hard to categorize, because numbers alone wouldn't do; it'd be more about proportions and shape. I seem to recall Steve Hed (or maybe Cobb, crap I'm getting older) hypothesizing once that high hands worked better depending on the riders hips size.
Cool.
But you had something janky in the link to the old 2007 thread, so I took the liberty of posting it below. It's too good of a thread for folks to not be able to just click :-)
http://forum.slowtwitch.com/forum/?post=1324075
Thanks for sharing... nice insights.
"Too Low/High" is always possible... it all depends on what point you are referencing as the "start"
I found my saddle could be raised 1cm with no effect on aerodynamics, but some relief in the hip angle. Front end was the same... dropping 20mm of spacers was almost the same as higher, dropping 40mm of spacers was worse than higher. Like all things aerodynamics... it depends.
Helmets only mattered a bit (comparing only the ones I would have guessed were fast) but skinsuits mattered a lot, even among some of the faster (or so I thought) TT options.
My Blog - http://leegoocrap.blogspot.com
Podium Sports Racing - http://www.podiumsportsmed.com/team/
Did you test different saddle heights in the wind tunnel?
Co-developer, WKO4 software, and originator of the following concepts: Coggan classic training levels, normalized power (NP), intensity factor (IF), training stress score (TSS), power profiling, quadrant analysis, the Performance Manager Chart (PMC) and associated metrics (i.e., chronic training load (CTL), acute training load (ATL), and training stress balance (TSB)), the WKO4 power-duration model, auto-phenotyping, 'WAC' score, elevation-corrected power, new individualized training levels ("iLevels"), gross power released (GPR), gross power absorbed (GPA), kurtotic index (KI), asymmetry index (AI), and maximum effective pedal force (MEPF) metrics to describe pedaling, and running effectiveness for runners. Consultant for Stryd, Inc. Previous consultant for Peaks Coaching Group, English Institute of Sport, adidas interactive, and Velocious Software. #someleadothersfollow.
Re: Some random wind tunnel observations and datapoints [Andrew Coggan] [ In reply to ]
that's what I want to know too +1
when I did, lower saddle was much faster
How many grams of drag did you have total? I'm curious what 100 grams of drag difference in helmets works out to be percentage-wise.
How many runs did you do total?
How much less drag did you have at 10cm of drop versus 14cm?
Regarding the increase in drag at 10 degrees of yaw on the Q-Factor change, did that increase occur at 10 degrees both left and right? Is it different drive-side versus non-drive-side?
Travis Rassat
Vector Cycle Works
Noblesville, IN
BikeFit Instructor | FMS | F.I.S.T. | IBFI
Toughman Triathlon Series Ambassador
Not in isolation. We raised the saddle by 2cm and bars by ~6cm at the same time. We made the latter change by switching from FSA Vision bars to 3T Aura Pros and adding a bunch of risers. Average drag was slightly (30grams) lower.
So no apples to apples --or even fruit to fruit-- comparison. More like fruit to vegetable. ;-)
So you don't know if raising your saddle hurt your aerodynamics. Do you know if it increased your power?
did you test the aura at the baseline as well or just completely wholesale nothing to compare swap?
Interesting results. Thanks for sharing. I wanted to add a couple points from my two trips to Faster with Ventum over the past two years.
This was my experience as well. Raising my pads 1 cm lowered drag. It also felt significantly more comfortable and powerful. This small change allowed me to shrug my shoulders and turtle my head more naturally.
My most surprising result was that my Kiwami ITU suit tested about the same or significantly faster than two sleeved suits. Neither fit really well and both had wrinkles in the shoulder area, which may explain the poor results. I'll be sticking with ITU suits until I can show that the benefits of sleeves outweigh the disadvantages for me (heat, effect on swim, slower T1...).
CodyBeals.com | Facebook | Twitter | Instagram | Strava
Ventum | Skechers | Martin's | EAS | STAC | Alto | Pioneer | Bliiq | Keystone Communications
Re: Some random wind tunnel observations and datapoints [Cody Beals] [ In reply to ]
I had the same thing happen with my Kiwami ITU suit except my sleeved kits actually fit really well with practically no wrinkles.
Since we tested "the whole system" rather than that specific measure, there's no way to say what raising the saddle by itself did. Power is definitely higher. But even that is reflective of a whole system change (i.e. less drop). Maybe in a week, I'll try dropping both the bars and the saddle back down 2cm and do a few power tests.
If you haven't read Cody's wind tunnel article it's a great read. I frequently find myself going back to it for reference.
regarding aero suits, how far and what would your limit on budget be to get two suits made custom to you, measured to your body in your chosen position on the bike?
Anne Barnes
FIST/SICI/FIST DOWN DEEP
Live Grit
anne@livegrit.com
Re: Some random wind tunnel observations and datapoints [ABarnes] [ In reply to ]
It depends
Re: Some random wind tunnel observations and datapoints [James Haycraft] [ In reply to ]
haha, excellent response.
ok, more exact question: if I was a BioRacer Speedsuit provider, would you come to chicago to get it fitted? two suits, with or without longsleeves, plus a little bit of time with me for about $2k.
Chicago is really nice this time of year. :)
Anne Barnes
Live Grit
anne@livegrit.com
It's more a $/watt question. If this custom designed GUARANTEED watt savings at the rate of say...$100/3-5w then I might consider it.
Thanks for sharing.
I wonder if people ever measured the drag of a racenumber with a belt which you have to wear at nearly every triathlon. Whether that deletes the advantage of a suit over two-part wear for example.
Related to that: I watched the WC Kona carefully again on youtube, but I didn't see any belts with numbers, also not with the AG, am I blind or do you not have to wear a number on the bike in Kona?
Re: Some random wind tunnel observations and datapoints [longtrousers] [ In reply to ]
You don't have to wear it in most IM races in North America.
Other parts of the world I am not sure. For example I think France requires it
longtrousers wrote:
Thanks for sharing.
Many years ago I tested race number position (belt) on my tri bike at a2, there was a 5 watts difference between low on my back and high (like a hr strap high) on my bike) and about 8w difference wearing it on my front (low back was best)
Wearing on a 2pc tri kit was worse than on a one piece (an old LG two piece and a 1 pc Desoto, both 2010'ish neither with any kind of sleeves)
Draw from that whatever (if anything) you would.
