Xavier wrote:
realbdeal wrote:
I bought a few tires after you mentioned they were faster. I have tubeless compatible wheels but have just stuck with latex as Michelin Power TT have always been my race tire of choice. Was thinking of making the swap for these though. Do you have any thoughts on running these latex vs tubeless and whether certain sealants like Silca's might leak from them?
These days I personally run latex tubes for all races. Your overall performance will improve by being able to swap tyres out depending on conditions etc. rather than sticking with one tyre setup on race day because de-tubelessing a wheel is a stress no one wants!
IF the new Corsa Pro Speed are amazing in other aspects - puncture resistance, wet grip etc. then there'd be an argument for leaving them on for everything and setting them up tubeless, but I think the ability to quickly swap out to something like GP5000TT for bad surface, Michelin PTT for wet grip, Veloflex Record 25mm clincher for ultimate speed means that latex tubes are a more versatile solution.
can i, the rank amateur, presume to present a contrasting opinion? i'm foolish to do so but, well, i'm foolish, so i will.
first, thanks for the test. second, this comports with vittoria's own claims. third, kaboom! goes the 5000 TT. well, not so fast, people treat conti like their politics and religion. but every reason for choosing the 5000 TT is now the reason to choose the corsa pro speed (it seems to me).
fourth, i just want to push back a little on the latex tube argument, at least in tri. there is what people ought to do. then there is what people do. and in tri - even at the highest levels - what people actually do neuters the reason for innertubes. there will be absolutely... no... changing... of... tires... to suit the conditions. practically no triathlete, at least in no-draft racing, at any level, has ever thought the day before a race, hmm, i think i'll change my tires because of tomorrow's weather. but...
many triathletes, virtually all triathletes, have asked themselves what they might do (that is not too much work) in order to lesson the likelihood of a flat. the way you do that is placing the sealant in direct contact with the tire rather than placing the sealant inside a latex tube.
i try to make it a point never to debate 2 people. josh poertner and you. but there i went and did that stupid thing.
Dan Empfield
aka Slowman
