marcag wrote:
Mudge wrote:
UK Gearmuncher wrote:
Mudge wrote:
Lest we forget, he chose those tires to go with the specific wheels he was running, and for different wheels he very likely may have chosen something else altogether.
I'd normally agree with you on such issues but there is a fair bit of anecdata and evidence that is indicating that the width on the rear - aerodynamically speaking - doesn't make a meaningful difference but RR does so its 28mm all day long back there. As for the front, I would agree with you that's where the careful matching needs to take place but I'm yet to be convinced that 28mm on the front is the best option when all the factors are taken on balance.
I think perhaps quite a few people are making a mistake of assuming that CRR trumps CdA in all situations, especially considering it was only just recently that people accepted that in almost all situations CdA trumps weight. This is compounded by the fact that for a good many tires, such as the Speed G and the Conti 5000, the RR is for all intents and purposes equal when pressures are adjusted for real world conditions. Sure, you can get a 28mm Speed G to roll as fast as a 23mm, but it will be an unreasonably harsh ride, one that would be minimally acceptable for the rear but far too harsh for the front, IMO.
Agree.
I have some road testing queued up in Feb and I will try and compare "optimal" pressure on wider/narrower and see if the rider can even perceive the comfort difference.
I think the thing that needs to be taken into account here (waving hands generally responding to all), is the conditions of roads. BRR has tested all the sizes and found no difference, +/- .2w, when all the tires are adjusted for sag. That however is on a mostly smooth drum and not a road. Vibrational losses start to add up as the road surface gets worse. I'd posit that a 26 and 28 will have very similar Crr on typical smooth-ish tarmac. The 28 will win out as the road gets worse and vibrational losses mount.
Another thing stated was that tires start performing worse at around 30mm, or Josh said something to this nature. We're already there. a 28mm on a 21 internal is just under 30mm. On a 22.5 internal it's slightly over 30. This is a New tire, after use they tend to expand a bit. For comparison a 25 on a 21 internal is ~27.5. A 26 is most likely 28.
Perhaps another thing to consider is weight of the rider. Vingegaard is child size. There less energy to dissipate than for the average or even elite triathlete. I have no doubt, given the amount of focus the team put into preparing for that TT that they wouldn't test all options and choose the fastest combinations for that rider.
Hopefully we can get some testing data soon on this new tire. I know there's also a Pista Oro Clincher floating around, but my sources have told me that it hasn't tested any faster than the VeloFlex Record on the track. Apparently Vittoria is still working on the compound. I think as a system the Princeton disc and Conti 25 TT is still fastest (track).
Heath Dotson
HD Coaching:Website |Twitter: 140 Characters or Less|Facebook:Follow us on Facebook
