OK...that's a lot of pad stack...let's see what it takes to get there on a Large SC7 frame:
the Large SC frame has native frame stack of 541mm...add 10mm minimum for the combination of headset cap and a 5mm spacer under the stem (Bontrager recommended minimum) plus 20mm for half of the stem clamp height. I believe the Brezza2 has about the same minimum pad stack as our SC RXL bar at ~45mm. adding all that up we're at 616 or so.
which stem angle depends on how many spacers 3T says you can safely put under the Brezza pads, and the length will fall out from that.
Carl Matson
Carl Matson
