neilridley wrote:
goneskiian wrote:
neilridley wrote:
There are 3 armpad drillings and 2 widths for the extensions depending on how much stack you runThanks. Yes, I'm aware of the 3 widths on the pads themselves and that the extensions are either 110mm or 80mm apart depending on whether I'm running them with or without the riser respectively.
I was hoping there might be a "secret" adapter (much like the extension adapters I found on another thread here allowing me to run
a ski tip extension) that might allow me to run the arm rests wider than those 6 settings. I'm pretty flexible so I have them mounted with out the risers but I'm also not a small dude and I think I may not be as aero as I can be by having my elbows that narrow.
Cheers!
Edit: Check that, I guess it was actually earlier in this thread that I found the aftermarket extension adapters. Maybe I should just sit down and plow through all 88 pages here. Ugh. ;-)
You mean something like these
http://i234.photobucket.com/...712d_zpsda8d1b5a.jpg
http://i234.photobucket.com/...6252_zps91deeb8a.jpg
http://i234.photobucket.com/...0276_zpse375ade3.jpg
Neil
Oh wait, I see what you did there. By putting the extensions below the riser you can get the arm rests back to the wide setting. Hmm, that riser looks different (mine is solid, no cut out in the middle). I'll have to see if I can mount mine like that too.
Thanks!
