mndiver wrote:
mauricemaher wrote:
Well better to dramatically make one mistake and learn than have 4-6 muddling preformances over 4 years (me) basically we have 125 pound females at 325 cal/hour on the bike stricktly carbs in liwuid form. So for a 5:30 generally looking at over 1800 inputs for a good set up on the run...where you are generally limited to much less (225 or so) Maurice
Did I read that right that you have 125 pound women who consume 1800 calories in liquid form? No solids? I could get on board with just liquids. I hate trying to cram down solids while racing. Always thought I needed to.
When planning nutrition you need to make certain assumptions IE:
Starting point calories at 7 am
Distribution of calories (systemic IE liver/blood vs localized.. muscle glycogen)
Distribution of calories according to % muscle mass (IE 2/3 legs, 1/3 upper body) I may be corrected on this but from what I have read it is very hard under load (race situation) to re-patriate stored muscle glycogen in the arms to the legs.
Again some more guesses:
You need to determine burn rate:
Swim…take a guess based on the info out there, also adjust your guess based in if you kick like a demon or swim with just a light flutter.
Even though we do metabolic testing for athletes specifically around execution at IM….a power meter is pretty damn accurate for gross calories vs power. I would say that the KJ or calorie function of a PM is the least appreciated and most under utilized feature of a PM (If you are racing IM)
On the run…plenty of pretty damn accurate calculators vs metabolic testing based on weight, ambient temp and pace.
Once you know burn rate then you need to (sorry) guess again…as to % contribution of fat vs CHO
For the sake of argument most FOP AG at .75-.80 IF are at about 60-70% Carbohydrate.
On the run it appears to drift a lot more with athletes starting at 60% and drifting up to 90% at the end for a given steady state….everyone is different here but thats what I see, from my basic experience you could perhaps guess at 70-75% CHO contribution on the run.
So once you know or guess at inputs then you need to experiment in training, for 1st timers perhaps 2-3 times a year with a special brick of 120km and 21 km at load or even faster at best effort, basically you are testing both GI distress and numbers in order to get a clear idea. You can go further and combine a swim at distance as well.
Basically very important to understand that from the minute you get up everything you do, every choice you make etc sets you up for the last 13 miles.
Maurice
