PhilipShambrook wrote:
If you only run in the one pair, then you should consider at least one other pair and alternate. Keeps the wear pattern from getting too extreme on one pair before you change them. I have at least 2 pairs, roughly half a life apart so that when one pair reaches death the other pair is on half life. Form likely does suffer as you deal with the discomfort from the ankle. Consider also whether you favour one side or the other during work and perhaps think about evening the loading a bit more.
I will definitely take your advise on a second pair of shoes though. 90% of my running is on a treadmill so my shoes wear a little slower. Mine are right about half life now so perfect timing! Thanks!
