Tom A. wrote:
The tire tested is the One model, not the Pro One.
Thanks for the quick and detailed reply.
I'm assuming you meant the standard clincher, not the tubeless specific one. In a post from a while ago, I talked about taking a video of puncturing a road tubeless tire (with sealant) at 90psi a dozen times with a thumbtack and having virtually no air loss as measured by the hand gauge. You made good points about the tire not being loaded or spinning. You then challenged me to jam a thumbtack into a latex tube and see if the same thing happened. Short story, you can patch latex tubes just like butyl tubes when they won't hold air after purposely popping them :-)
The crr of the (previous generation) One clincher seems to closely match your 2013 crr measurement of a 22 Schwalbe IM clincher at 0.0041. The tubeless version of the 22 Schwalbe IM (brand new) measured 0.0035 in your test. I'm really curious how the results would have looked if it were tubeless specific Ones used for the FLO test. Averaging your 30km/hr and 40km/hr columns and accounting for 1 tire instead of 2 would have me believe the removal of that puncture belt is worth 2-3 watts per tire in the low 20mph range. That would make a much more compelling case on the FLO charts since so much of it is based off crr. The new Pro One is supposed to be even better for crr too.
I feel that tubeless Schwalbe road tires make sense for instances where you want stable psi or are at risk of small punctures from things very similar to my thumbtack. I had Vittoria tubes that each lost 20psi during a ride. The newest tubeless tires don't appear to be giving up much to the cream of the crop 'fast' tires and hold PSI really well. I'm on my 3rd set of road tubeless tires with a 4th pair of 28s ready for my cx bike. I have had one full flat that whole time and it was because the rim tape failed. Dealing with the sealant while throwing a tube in wasn't fun, but it was far from the horror show that ST would make one believe fixing a flat on a tubeless tire would be.
Anyhow, I would still pick the Supersonic (If I can ever find them in stock) and latex tubes (without a patch) when every watt matters. I would probably ride my next IM bike split on well chosen Schwalbe tubeless tires again.
