In Reply To:
Actually, my first response was the weight issue.
Right...and I was responding to your assertion that the pinch flat "issue" was the most important part of your response.
In Reply To:
Zipp 404 Clincher with a GP 4000 is going to weigh about 522 grams MORE than a Zipp 404 Tubular with Competition 22's. That is a little more than pound, which falls in line with my original assertion that UP TO a couple of pounds could be saved with tubulars. SO, because I am a weight weenie, for me it is weight issue, and now I've provided DATA to back it up.
Finally! Data! However, I'm sad to say that you may be a bit high on the weight difference. I've run the numbers on 404 clinchers vs. 404 tubies (using "apples to apples" tires - Vittoria Corsas and Open Corsas, latex tubes, and rim strips) and I got a weight difference much closer to 450 g (or, 1 lb. Hence my assertion that the weight diff was closer to 1 lb than to "a couple").
While I also tend towards "weight weenie-ism" in bicycle equipment, in this case your "weenie-ness" may be somewhat misplaced. Obviously, the trade-off here is weight vs. rolling resistance. By going with the lighter wheels you're required to take a hit on rolling resistance. If you're going to be racing on flat terrain, the obvious choice is going to be to use the setup with the lower RR, right? Conversely, if you're hitting hilly terrain, the best choice is going to be the lighter setup, right?...Well, not so fast.
Logically, there is going to be a certain steepness of hill where the better rolling resistance of the clincher setup will be offset by the lighter weight of the tubulars, correct? Anything less steep and the clinchers will have an advantage (due to their RR), and on anything steeper the tubular setup will win out (due to their lower mass). OK, so what is that steepness?
If you run the numbers (I have...it's basic physics) you'll find that "break even" point to be over 9% grade! That's right...at every grade below that, the clincher version of the 404 will be faster. Now...that's comparing one of the best rolling clinchers to it's tubular "twin", which also happens to be one of the best rolling tires of _its_ type. If you are running slower tubies (i.e. an "average" one, like a Conti) then that "break even" grade is even steeper. Shocking, huh? Conversely, if you're insist on running a slow clincher, that grade will be shallower, but not by much.
This is actually one of the few cases in bicycling equipment were to get faster, you actually have to add weight.
Oh yeah...please don't trot out the "rotating weight" argument. That's one dead horse that doesn't deserve to be beaten once again.
So...in summary. Tubulars rule (especially Tufos) and every tire should be pumped up to it's highest possible pressure. Carry on.
