bluesmachine wrote:
Super Dave: When you say that 'delivery has been delayed to December' 1) what was the original delivery date and 2) is that a 'delivery really confirmed for December' or 'should be by December 31st and more likely January / February' ...
I ask this not to needle but as a realistic question with the 2014 season really not that far away...
Also, will this bike have the 'Do not use on a bike trainer' sticker that I believe your DA had on it?
Thanks in advance.
There are over 116 individual parts that need to arrive to build the bike. I expected them to all be finished but some items that are being made here in North America haven't made it to Taiwan where the complete bike is assembled. Transit times often have 4-7 day windows both to Asia and back to the USA. I have no idea where you plan to buy your bike but UK deliveries would be a few weeks after Southern California as the port is much closer.
Since there is no risk on my part, I'll say the bikes should arrive December 18th. It would be exceptional and a big failure for Felt and for me personally if the delivery of the IA was postponed until February.
As the frame is manufactured with carbon fiber, like the DA, I'd advise against an axle/fixed wheel mounted trainer that puts the stays in tension and high torsion, rather than the compressive forces it is designed around. A set of rollers would be perfectly fine.
With that said, I cannot recall a failure we've had as a result of normal use on a trainer, but I've seen a few from the bike slipping out of the Q/R clamp and falling over crushing the seat stays.
-SD
https://www.kickstarter.com/...bike-for-the-new-era
