trirocket wrote:
Did you see the attachments? What are your thoughts?From a diagnostic viewpoint, if I have this correct in my head, you had none of this weakness or sensory changes prior to getting the acupuncture performed? None of this was occurring after a period of time on the bike etc??
Some others have mentioned iliac artery fibrosis-yes this can happen, but you do not tend to get symptoms when you are not exercising as such, you should not have weakness sensory changes with this at rest.
Looking at the areas you say you have the sensory changes (I presume this is the picture with the red circles, and the one with the yellow circles is where the acupuncture was being performed?), it almost certainly looks like injury to the sciatic nerve and common fibular nerve in the region of the top of your popliteal fossa (the area behind your knee, at the top end of this). This does correlate to the signs and symptoms you are getting. I will attach two links which run through the areas that both nerves have sensory innervation (ie where you feel them on the skin) and motor innervation (ie what muscles they control and therefore where you have weakness). As an FYI, what is termed plantar flexion is the ability to push your foot down, ie like stepping on the gas in the car. Dorsi-flexion is the reverse, ie pulling your foot up. What we call a foot drop, ie your foot drops down because you cannot control it, is generally an issue with dorsi-flexion, ie you cannot keep your foot pulled up.
The symptoms you have fit with an injury to your sciatic nerve around about the point that it bifurcates into the common fibular and tibial nerves. These two nerves account for all the symptoms you are getting and line up with where you appear to have been getting acupuncture. It would be interesting to know if it was during the needles being put in around this area that your symptoms started.
Here are two links which show those two main nerves:
https://teachmeanatomy.info/...ommon-fibular-nerve/
https://teachmeanatomy.info/...nerves/tibial-nerve/
When you injure a nerve in this way, unless you transect it, you still have function in parts of the nerve.
When we do peripheral nerve blocks etc we do not put our needles into the nerve itself, as this damages the nerve, and then if we inject local anaesthetic etc into the actual nerve itself it can cause serious damage. We aim to deposit the local anaesthetic around the sheath of the nerve, hence why we commonly use ultrasound for these types of nerve blocks.
Have a good read through all of that and let me know if those signs and symptoms match what you are going through.
Also, has there been any recovery whatsoever?
Finally, where in the world are you based? (that can dictate what sort of recourse you may have able to have)
Without wanting to be the bearer of bad news, if this is the case and you have not had any improvement since this happened, the chances of you having any further meaningful recovery are very small (hence my comment in relation to whether you may have any recourse).
Hope this all helps.
Usual disclaimer. Despite being an MD this is the internet and hence any opinions expressed here should be discussed with your own doctors who are able to perform a proper history, examination and order any investigations that may be required. (have to say that to cover myself)
