Ironnerd wrote:
As a BOP I do a full change in T1 and T2. I am out there a long time so comfort is important.
One thing to consider is sun protection. If the IM you are doing is hot and you are going to be out there for 10+ hours a top with sleeves and longer shorts provides sun protection. I race in the heat of Australia. I wear calf compression sleeves and arm coolers for sun protection.
Sun protection and heat management is no small thing to me either - also racing in Australia. I use a one-piece with an aero cycling jersey over the top. Works fine under a wetsuit and the sleeves + longer legs eliminate sunburn on shoulders/thighs. Plus, the jersey is apparently faster too....
Can take the jersey off while running if I feel hot/claustrophobic - but it is almost weightless and has a front zip so its pretty cool to run in.
Never unzip to pee - just lift the leg. Quick & simple.
