xtrpickels wrote:
wheelzqc wrote:
How do you set the tilt ? Level nose to tail ? What about fore aft? Around 3 more then previous saddle?Missed this previously.
If you put a level from the nose to the rear of the saddle, it should be a few degrees nose down.
What you're looking for is that the front half of the saddle is level with the ground, while the back half kicks up a bit.
If the saddle is completely level from tip to tail, the front half will actually be sloping up.
Obviously personal preference plays a large role.
The below image is probably ~ 1 maybe 2 degrees nose down from where I would set it, personally.
The last image is too nose up.
With the power it is working for me for tri best in the first picture view. It kind of sucks in the second view. Pretty well all other saddles, I prefer level as in the second pic.
