Hi Greg.
Creaks in your bottom bracket and bolts that either come loose or were loose to start with are common problems on new bikes. It's also common for it to take time for your body to adjust to a fitting and even to make minor setup changes after a fitting. I don't think that has anything to do with Felt or Bikesport.
It's fair to have high expectations when you drop $4500 on a bike, but it is common to have minor problems in the first few rides on a new bike. More exotic bikes are also usually less reliable than mid-range bikes, so the chances of odd problems are only magnified when you are dealing with carbon and titanium doo dads.
Any bike shop can fix your creaking BB and tighten up your handlebar binder bolt. Maybe in this case you should take your bike to a LBS and have those two problems fixed. You're still getting the best of both worlds: Quick availability, a good price, and a good fitting from Tom and good service from a local shop.
Good Luck,
Marc
Good Luck,
Marc
