Right.
Re: BMC TM02 + Ultegra Di2 battery mount - help! [elcartelduco]
Re: BMC TM02 + Ultegra Di2 battery mount - help! [branng]
Hey Branng - I'm new to this forum and had some questions about your build. I currently have a 2014 BMC TM02 and was thinking about the upgrade to Di2. Could you help me answer the following?
-What kind of battery did you go with? The older external SM-BTR1 or the newer internal one that's skinny & long (SM-BTR2)?
-If you used the older external one, is it a big hassle to remove your wheel and battery each time you need to charge it?
-Where did you hide your Junction A box? I don't see it in your front cockpit area.
-Where is the Junction B box? Inside the down tube?
Thanks in advance.
Thanks in advance.
Re: BMC TM02 + Ultegra Di2 battery mount - help! [davidxtwo3]
It's been awhile, but I was able to get my di2 setup on my BMC TM02 all concealed. EVERYTHING is hidden!
Nice rig!
I've the exact same question you poised, what battery option did you go for and where did you mount it in the frame?
Thanks
Thanks
