At that point I would probably just eBay it, and buy Di2.
Re: SRAM eTap Rear Derailluer Failure [cfos118]
Re: SRAM eTap Rear Derailluer Failure [nickwhite]
afraid it's sram etap only on my frame or back to mechanical (no thanks). I will stick with etap for the time being.
cfos118 wrote:
afraid it's sram etap only on my frame or back to mechanical (no thanks). I will stick with etap for the time being.New bike time!
nickwhite wrote:
Always time for a new bike.
Favorite Gear: Dimond | Cadex | Desoto Sport | Hoka One One
Re: SRAM eTap Rear Derailluer Failure [The GMAN]
Quote:
Always time for a new bike.If only wives felt the same way. :)
Re: SRAM eTap Rear Derailluer Failure [GingerAvenger]
Just had my eTap rear der. fail today.
It seemed to "fall asleep" during my previous ride, but would "wake up" after a front shift. Since this only happened twice, I brushed it off and forgot about it.
Today, 30 Km into a ride, nothing. Nada. No movement. No shift for you.
- Shifters work
- FD works
- All four batteries have juice.
- Green LED lights up on RD when I press the shift button
- Bought in May 2018
- Ridden 2,800 Km
coming soon...
- Shifters work
- FD works
- Ridden 2,800 Km
coming soon...
Re: SRAM eTap Rear Derailluer Failure [alex_m]
Sounds like the servo motor is toast. Your 2x11 is now a 2x1.
Yup. That's inline with symptoms. Hoping my lbs will show some love
coming soon...
coming soon...
alex_m wrote:
Just had my eTap rear der. fail today. It seemed to "fall asleep" during my previous ride, but would "wake up" after a front shift. Since this only happened twice, I brushed it off and forgot about it.
- Shifters work
- FD works
- Ridden 2,800 Km
Go through the full pairing process. You describe a somewhat similar situation I had mid way through a ride, and it ended up being that some how it unpaired itself. A friend happened to roll up to me with etap and said I should try to pair it... lo and behold, that solved the issue. He and another friend have had the same issue as me, so it’s not that uncommon to happen with etap,
wetswimmer99: Aug 22, 18 19:21
Re: SRAM eTap Rear Derailluer Failure [wetswimmer99]
Would green LED on the RD light up if it were unpaired?
In any case, will try pairing and report back.
coming soon...
coming soon...
They may give you outstanding service like they did me,when my wired Red RD blew apart for no reason. I contacted them & they wanted my shop to deal with it. My shop said the RD from Red early on were crap & they don't know why SRAM would say bring it to them, just because I bought it there. It was just past warranty but still, had to fork over for a new RD. Same with shifters--replace R2C's many times with rebuilds..."Don't Make the Leap" is what the motto should read. Shimano or go home next time for me.
Just tried pairing the system again.
No dice.
Bo-urns.
coming soon...
No dice.
Bo-urns.
coming soon...
I just had this same issue and contacted SRAM. They quickly replied instructing me to return the derailleur with proof of purchase to the bike shop where I originally bought my etap group set. Unfortunately, I am not in the same country where I originally bought it a few years ago so I cannot return it to the bike shop for warranty replacement. So now I have a nice expensive paper weight :-)
Re: SRAM eTap Rear Derailluer Failure [Aboy Dekid]
Or what happens when the place you purchased from no longer bike exists... “going back to the original supplier “ is an odd requirement for sure I get why they do that - I believe they are trying their best to protect the local bike shops, which I can respect and opposite of Shimano who does nothing to help LBS. in my case, not RD, but blip and battery, another LBS has been helping me and I haven’t gotten the run around. That leads me to believ the LBS where ever you are now located can help along with their SRAM dealer, if they wanted to.
Aboy Dekid wrote:
I just had this same issue and contacted SRAM. They quickly replied instructing me to return the derailleur with proof of purchase to the bike shop where I originally bought my etap group set. Unfortunately, I am not in the same country where I originally bought it a few years ago so I cannot return it to the bike shop for warranty replacement. So now I have a nice expensive paper weight :-)I had the same thing happen when my right shifter fell apart, and the original LBS was a long ways away. I found the closest LBS near me that was a SRAM dealer, and they were able to arrange a full (free) replacement with SRAM.
Re: SRAM eTap Rear Derailluer Failure [Tailwind10]
Hi did anyone sort out the orange flashing light on the sram etap shifter
