I may have one of the Praxis adapters mentioned below for sale. Excellent condition and ultra-low miles; I just ended up getting a "native" BB30 crank.
I'll check tonight and reply back, if you're interested.
Save yourself a lot of trouble. Just don't get a BB30 frame. My latest book: "Out of the Melting Pot, Into the Fire" is on sale on Amazon and at other online and local booksellers
Have you used Ceramic Speed for this on my S3 to run a GXP Crank. Not sure how much you are looking to spend, but I felt like it was money well spent when I made the purchase a few years back. No issues to date with it and still buttery smooth by just doing the basic grease of the BB 1-2x a year depending how much I ride and what the conditions are. -Brad Williams Website | Twitter: @BW_Tri |Instagram: @BW_Tri | Strava | Co-Founder & Coach at: KIS Coaching Partnered with: Zoot Sports | Precision Fuel &Hydration | ISM
I'm using that on a Slice, and I had to trim down some of the plastic around the adapter for it to stop rubbing. I don't know if it was an alignment issue with the frame, or the adapter being wrong, or if I was missing some kind of washer. Either way, after trimming a mm or so off the adapter it works fine and I have no complaints. I think it creaked once, but a little regreasing and it was fine. _____________________________________________________ George Dedopoulos | @geodee | geodee.com | Team Atomica | Toronto Triathlon Club
This Wheels Mfg complete bottom bracket solution has been the bees knees for me. Only regret is that I didn't buy it sooner and dealt with plastic sleeve adapters and creaking, crappy BB30 bearings:
Same here. I prefer it over the Praxis unit because it doesn't have holes in the sleeve. Those holes let in water and grit from the seat tube and cable guide that exits near the rear tire.
+2 on this- I just put one in my MTB today. PF30 to GXP- no adaptors or other funny business.
+8 (I think that's the correct math) for the WheelsMFG BB. I have them on 3 bikes. I once had horrible creaking and swapped out the BB, nope, it was the Zipp wheel bearings (AGAIN).
