I would like to compare two power files (quarq vs kickr)......what program can I use to lay the two graphs on top of each other?
Re: What program to compare two power files [Mike Alexander]
I use R.
Re: What program to compare two power files [RChung]
RChung wrote:
I use R.What is that?
I thought WKO did this type of analysis.
Re: What program to compare two power files [Power]
Power wrote:
I thought WKO did this type of analysis.It would let you plot the data vs. time or distance. If the files aren't already reasonably synchronized, though, you'd be better off doing the analysis in e.g., Excel.
Golden Cheetah is great for this.
I've used it for this scenario on many occasions.
Re: What program to compare two power files [JulianM]
JulianM wrote:
Golden Cheetah is great for this. I've used it for this scenario on many occasions.
Does it have a synch function? That could be handy occasionally.
Re: What program to compare two power files [Andrew Coggan]
It's not a feature I've ever felt like I've missed TBH.
If I'm not comparing 2 entire files it's easy to create intervals within the ride file and compare them instead rather than the whole file if syncing is an issue.
Mike Alexander wrote:
I would like to compare two power files (quarq vs kickr)......what program can I use to lay the two graphs on top of each other?Goldenchetah's Compare Pane allows to do this at activity level or even at interval level, which is useful to compare parts of a ride and/or to force alignment. For more advanced analysis as suggested by Robert you can use R embedded in GoldenCheetah.
Ale Martinez
www.amtriathlon.com
JulianM wrote:
It's not a feature I've ever felt like I've missed TBH. If I'm not comparing 2 entire files it's easy to create intervals within the ride file and compare them instead rather than the whole file if syncing is an issue.
I'm confused...are you're saying that it doesn't have a synch function, but just plots data vs. time/distance? Dozens of programs do that.
Which is exactly what the OP asked for so I suggested one that might be of use.
Perhaps you could help him out too by listing some of the dozens of programs that also might help him, other than Excel which you mention, so he can make an informed decision.
