Hello BryanD and All, Thanks .....
I like this one ..... (Disclosure .... We make and sell them)
http://www.shop.view-speed.com/...ool-610098716037.htm We are temporarily out of the aluminum/Ti model ... 24 grams ..... but have in stock the all Ti model which is stronger .. . 28 grams plus the bits you select that fit your bike. The handle serves as a tire iron.
If you have the View-Speed S4 skewers ..... the 3 blips are a spanner matching the skewer ...... or you can use the 5mm hex bit.
For the ingenious ..... you can fill the 5mm hex part of the S4 skewer with epoxy and make it only work with the spanner for some extra wheel security.
The steel bits (selection of blade screw driver, torx, hex/Allen, etc.) are security bits with a hole so they also work on security fasteners .... and that makes them a BIT lighter (pun).
For those times when you are incarcerated you can unscrew the window fasteners in the toilet and escape .... keep this tool with you at all times.
Cheers, Neal
+1 mph Faster
