Pad reach: 460 (center of pad)
Pad stack: 690
Saddle height: 842
arm pad drop: -131
saddle setback: -47
inseam: 35" (889)
height: 6'1 (1860)
Bike: Cube Aerium HPA Pro
saddle: ISM adamo prologue
So I'm looking to purchase a Felt IA10 frame but using the numbers above I'm not sure if I fit a 56 or any at all. Using their calc it says a 56 with a 40 + bridge + 5 +10 and moving pads back -32mm but its only an "OK" fit.
What appears to be strange is my saddle height for my inseam, typically I believe for a 35" inseam a saddle height would be 785, not 842. And hence with a high saddle comes a higher pad stack. What could contribute to a much higher than normal saddle height? Crank is 172.5, pedals are Garmin vector, cleats are look keo, shoes are size 11, my ankle angle at near bottom of stroke is 29 degrees. I have a whole host of other numbers from a retul fit from a good while back if needed or I can also email you the report.
Pad stack: 690
Saddle height: 842
arm pad drop: -131
saddle setback: -47
inseam: 35" (889)
height: 6'1 (1860)
viperlogic: Sep 21, 16 14:23
