I posted this over on the Garmin forums, but I thought ST might be able to help, although I couldn't find similar issues via search. Yes, I have the latest Quarq firmware, and yes, I have the latest 520 firmware.
I switched from the 1000 to the 520 and I'm having different issues with two of my crank based power meters. These were non issues with the 1000...
Going into sensor details for Power Meter 1, there is no option to set the crank length--there is no field for crank length at all--which I believe is a problem? Anyways, I'm running 165s on this meter and the default (I'm pretty sure) is 172.5. I had no problems setting the 165 length on the 1000 with this same meter.
Going into sensor details for Power Meter 2, there is a crank length field, which is set at the default of 172.5 (however, it's a 170). When I try to change it manually--I've tried 170, 170.0, etc.--I get a blank screen that freezes the unit until I press the start button, which starts activity and brings me to the data screen.
Really frustrating...
