2011ironorbea wrote:
I am in the same process, but not as far along as I am piecing everything together bit by bit. Where did you find the baseplate for the cleats? I have only found one or two and they only have one mounting option. I noticed Simmons uses an aluminum plate where it gives you multiple position options, I was trying to find something similar to that but I guess they probably make those in house.
I am also planning on adding othe mounting locations to add pieces to the bottom to make it easier to walk in. I will also be lining the whole inside of the shoe and possibly adding drainage/air vents to them as well.
Are you planning on going sockless or are you wearing socks? If your wearing them, did you account for them in the molding process? Also did you mold your foot using STS casting socks? Weighted or unweighted on the foot.
I found a good site that has a good price on the casting socks and I did my first mold with weight placed on the foot after standing on a foam mat. I am now at the point of finishing the mold off (adding some to it to account for socks and felt liner), and also waiting on CF to arrive and my new vacuum pump and bagging supplies
I molded my feet barefoot with regular plaster cast wrap (its like $8 for an 8" wide roll that is enough for both of my feet). Problem is because toes are so easily compressed, no matter how I tried to keep it loose around the toes, the positive ended up with toes too crowded. So I put my toe spacers on, and then wrapped around that. I did what Simmons and other companies recommend: sitting in a stool, with my foot on a semi-soft surface (folded towel), partially weighing the foot down, making sure kneecap was over 2nd toe and leg as much straight up/down as I could eyeball. From what I can tell from trying the shoes on, it feels pretty good in the toe box. I plan to wear them sockless. I will probably drill some vent holes in the bottoms.
The baseplate is the plastic adapter plate that came with my Speedplay pedals. I figured it is better to try to epoxy plastic to the CF, and not worry about any metal- resin-CF interface.
Two wheels good. Four wheels bad.
