Anyone have any info on what happened to Crowie this past weekend at Geelong? I had read an article that he had a mechanical but no confirmation or details were given.
Re: Crowie's result at Geelong 2016 [Phoenixrising]
From what I understand it was a mechanical where his handlebars snapped. The Ironman tweets said Crowie took full responsibility for the mechanical, so I'm guessing that's either a PR move or he didn't assemble his bike correctly.
Team Zoot 2023
Team Zoot 2023
I raced that- he was in a good position out of the water, there were some super fast swimmers in the pro field, near the end of the bike he had a mechanical (which I am not sure the exact details) he took full responsibility for it.
He would've spent at least an hour in transition likely taking in what was going on in the race, I saw him when I came into T2 and then at the end of the first (of 2.5) laps on the run.
He was as always a class act throughout the whole weekend.
http://twitter.com/willrc91 --- instragram.com/willrc91
Re: Crowie's result at Geelong 2016 [aerobean]
aerobean wrote:
From what I understand it was a mechanical where his handlebars snapped.Maybe it had something to do with his clownishly small bike. Enough spacers bro?
https://www.facebook.com/CrowieCraigAlexander/videos/10154603285627516/
Re: Crowie's result at Geelong 2016 [kileyay]
2014 World Time Trial Champion:
Ed O'Malley
www.VeloVetta.com
Founder of VeloVetta Cycling Shoes
Instagram • Facebook
Re: Crowie's result at Geelong 2016 [RowToTri]
the difference there is that Wiggo is on the right sized bike and Crowie is not.
Re: Crowie's result at Geelong 2016 [ericM40-44]
For what reason? Is there not a legit reason you may want your base bar to be well below the pads? Perhaps you want to stay low with your hands on the base bar? Perhaps they found it to be more aero to have space between your forearms and your base bar?
Ed O'Malley
www.VeloVetta.com
Ed O'Malley
www.VeloVetta.com
Re: Crowie's result at Geelong 2016 [Willrc91]
Willrc91 wrote:
I raced that- he was in a good position out of the water, there were some super fast swimmers in the pro field, near the end of the bike he had a mechanical (which I am not sure the exact details) he took full responsibility for it. He would've spent at least an hour in transition likely taking in what was going on in the race, I saw him when I came into T2 and then at the end of the first (of 2.5) laps on the run.
I heard some nuts weren't tightened up properly.
RowToTri wrote:
For what reason? Is there not a legit reason you may want your base bar to be well below the pads? Perhaps you want to stay low with your hands on the base bar? Perhaps they found it to be more aero to have space between your forearms and your base bar?I believe Jim from ERO has posted that the cockpit area is a major area of drag on the bike and by adding spacers, while adding more volume, you actually clean up the cockpit from an aero/cda perspective.
that's not what I'm talking about. The frame is too small, in Argon sizing, not relative to other types of bikes, say his narrow tall Specialized Shiv. One size bigger is all I'm recommending, to give him / make him use a little more reach.
RowToTri wrote:
For what reason? Is there not a legit reason you may want your base bar to be well below the pads? Perhaps you want to stay low with your hands on the base bar? Perhaps they found it to be more aero to have space between your forearms and your base bar?Eric Reid AeroFit | Instagram Portfolio
I am no expert but have to agree. First thought I had when I saw the video of the new bike is that the bike is too small.
