Quote:
Curious what you think of the knee tracking tweaks fitters can make using the Retul by changing cleat placement. It seemed to me during my Retul fit that undue wobble in the knees, or especially in one knee vs. the other, remedied by making minor changes in cleat position, would be an advantage if that 'wobble' or asymmetric power application is impossible or very hard to see by naked eye.
Knee tracking: Again, does the retul system tell you what to do with the numbers you get or the knee tracking image? I think it's a great diagnostic tool!
What I think about knee wobble and how to correct that is a whole other topic. For me, I don't believe it should be standard operating procedure to force body segments into a particular plane of motion. Often times we don't know where it's coming from, but because we can, go directly to the foot. I'm not saying it's wrong, but I don't think we know enough to have every bike fitter in the country trying to make sure every cyclist has perfect knee tracking.
Quote:
Also, when you say "all it does is give you numbers", maybe you downplay the value of that, because in some respects it is the most important output to your fit inputs. I've had both types of fits and the Retul report as my takeaway, with specificity down to the mm on stack/reach/saddle setback in particular, make it much easier to replicate that position on other bikes. Without an x/y tool, I personally find it ridiculously hard to get precise about those numbers (even down to a half cm of error). Some fitters are so negligent they don't even take those measurements as an output of the fit process. Retul is worth the extra money for just that, in my experience anyways
I'm not downplaying it and personally use all the new fit technology that is available. I believe in being able to measure things with a certain degree of accuracy, or what's the point of measuring it to begin with. However, I don't believe it's the most important part of the fit. If you're not a good bike fitter, it's garbage in and garbage out.
Dan talks a lot about this when people start asking about which bike is best for them based on a set of fit coordinates. The first step is to make sure the fit coordinates are that of a well conducted fit.
I can grab anyone off the street and within a day, teach them how to run a fit tool. Specifically to the retul, someone can bury their head in the computer and make the basic measurements read green, but the fit is terrible. This is true of all fit tools in my opinion. They make our job as a fitter easier, more precise, time efficient, (your example of measuring the bike is perfect), but none of these tools will do the fit for you.
Mat Steinmetz
51-SPEEDSHOP.com -
instagram -
@matsteinmetz -
facebook
