About the Adamo, (Im a Road TTer not a Triathlete) I keep scooching back on it when I do my hip angle closes, and cadence slows and then it feels too wide, and I'm sure it creates tension in my low back and also my shoulder angle opens more when i sit right on the nose of it then it feels like the saddle is too low and feels like alot more weight on the front end, would highering the saddle allow me to sit towards the nose the saddle
If I move it back I will get the same affect, closed hip angle open shoulder angle, cadence drop etc?
I am 1cm lower then what my retul fit put me at and a tilt of the adamo is currently at 2 degrees the retul put me at 5degree down tilt because it felt uncomfortable but I didnt give it a good try on the road
Would going back to the retul fitting 1cm higher saddle, prevent me sliding back on the adamo? I think the moving forward and back is whats causing me chaffing close to the bones to the front closer to the manhood, the pubic rami I think. ~The rubbing/chafing is on the soft tissue a bit narrow/more in front right in the lower groin that attaches to my ballbag of the pubic rami I have a line that looks like the adamo slicing in.
Chammy cream does not help at all
Video of retul fitting position
http://www.dailymotion.com/...0150113-111206_sport
retul fitting info
http://www.scribd.com/...kiia-F1-ZERO-Sam-pdf
retul fitting info
