Hi Brad-
Photo didn't come through.
On the draftbox lid question, the first thing I'd check is that yours is the latest design...should have four squared-off tabs like this:
Then, make sure you've got that small tab at the forward edge fully engaged in the slot on the box before closing the lid...sometimes it seems like it's in there when it's not. Likewise check that the main tab at the rear has fully engaged once the lid is closed. Finally, when the lid is closed there should be no gaps all the way around the lid...there's a small ridge on the upper rim of the main compartment that should not be visible when the lid is closed.
Carl Matson
