robgray wrote:
Silasgnom wrote:
Great with some measurements on the Torhans 30. Have been looking for these a few times...
I will try to see if I can formulate this question so it actually makes sense:
What is the distance from the back of the mount (or the part of the mount that's in contact with the extensions) to the back of the lower part of the bottle?
Curious to know this as it seems to be essential to get the bottle as close to the frame as possible and I want to make sure that I can get the mount as far back as this require.
did you get an answer to this? I'm considering the torhans but also need to know the same thing. I'm not sure my frame is "close" enough
Did you guys ever figure this out?
I modified the mount a little to allow the 30 to sit flush against the stem. I think I measured the mount and there was a good half inch that prevented good contact. I cut the mount at the bottom of the "U" (so that I had two separate parts), drilled holes, then zip tied them together. Now, the bottle sits flush against the stem and is as close as it can get without causing interference on the frame itself.
