Superdave, I have completed a bike fit and am interested in the B12 (maybe B14). I have a very tall front end fit. I have an elbow pad stack of 770 mm and a reach of 530 mm. Seat stack is also 770 mm. I can't seem to find details of the Bayonnet 3 dimensions and possible adjustments. No local shops have B12/B14 to look at. I think with a size 61 frame if I used a 25 degree stem flipped up, 120 mm length, and a 40 mm spacer on the aerobar my pad position is pretty close. Is it possible for you to check that? Can the elbow pads be mounted ahead of the base bar?Would you have any other recommendation?
At each shop I have visited I get a deer in the headlights look when I start to talk about stack and reach. I think I'm on my own for getting this right.
Thanks for your help.
