Calculate your CdA... wind is ok. UPDATE
There is a lot of interest regarding aero drag coefficients in TTs, and AFAIK there aren't any good protocols for determining this if there is wind. So I put something together that seems to work. I've only done one series of tests though. Unfortunately I've discovered that a flatish section of road with a steady grade may be even more difficult to find where I live than a windless day! I've used this on several people's TT files lately... which isn't the best way to use it, but if that is all you have it will give you a ballpark idea of your drag coefficient.
Anyway... ask questions, give it a try if you are interested, and let me know how it goes.
Updated 2013.06.29 with entrance and exit speed inputs to account for momentum.
http://www.whitemountainwheels.com/CdA_Calc_2013_06_29.xls
You need a section of road with a consistent grade (~zero is best), where you can ride at a consistent power and speed. You'll do out-back runs over this segment and record average power and speed. Around 1 mile long is probably best, so you can have enough data points in each run and still do several "laps". If you have a GPS, it's easy to create these segments in Strava.
No traffic... unless you want to know how traffic effects your drag.
You need to be fully up to speed before you enter the segment. I recommend allowing at least .25 miles for this.
How hard should you go? Up to you. Power to overcome wind drag is porportional to speed ^3, so don't go too slow. If you wish you can make this an interval workout, or ride below FTP if you are tired. Varying your speed between runs can be instructive for looking at other variables, but that is more of an advanced topic.
Even though wind is allowed, it's best if the wind speed and direction are consistent during the runs. Also, strong winds are inherently more variable in their effect and will increase the variability of results.
Crr needs to be input. I assume a value of .004 (85F baseline) for the "good" tires (like Vittoria Corsas and Conti Supersonics) with latex tubes on nice pavement, and scale from there based on roller tests. Crummy pavement can increase Crr substantially. Also note that Crr is effected by temperature, and hot pavement can boost your tire temperature well above ambient. A ballpark guess for the temperature effect is ~0.8%/F... but don't worry if you are unable to measure it. So long as it isn't varying a lot during your runs, at least your numbers will be consistent. If you are trying to determine CdA on two different days when the tire temperature is likely to be very different, then you should consider it.
The Crr number also includes bearing friction, but if your bike is well maintained and adjusted, this should only be a few watts... around 10% or less of the total rolling resistance.
Environmental conditions can be found at a nearby airport, or other good weather station if no airport is near.
Regarding wind speed, at bike level the wind is usually < 50% of airport data and could be much less if the road is sheltered.
I assume an 8 watt drivetrain loss if you have a crank PM. This should be a good approximation for power >100W or so.
Pay attention to and keep track of the wind speed and wind direction (qualitatively at least). For each out-back you will input a guess for wind speed and direction. Even if you feel it was calm, don't input zero for the wind... start with at least 1 mph. It is also best to start with the wind guess not directly in line with your riding direction.
The calculation assumes that the wind was constant for each out-back, and adjusts wind speed (with angle fixed at your input), and then wind angle (with wind speed fixed at your input), so that the equations of motion are satisfied in both directions. If the calculated CdA for the out and back segments match, then you know it converged.
Unless you got lucky though, the CdAs for the two cases where wind speed and angle were adjusted will *not* be the same on your first try. You then have the choice of changing your guess for wind speed, wind angle, or both.
There is more than one "correct" solution for wind speed and direction and this will effect your calculated CdA a small amount, so make sure that both are realistic. For instance, say you end up with a 4 mph wind that is 45 deg from your direction of travel. An 8 mph wind that is closer to perpendicular would also solve the equations and result in a slightly different CdA number.
When all 4 calculated CdAs match and the wind speed and direction numbers look realistic, then you are done with that run.
Averaging more runs will reduce the random errors (the wind mostly)... I'd suggest at least 4 out-backs if you want a good number. Accuracy? Don't know yet. Even if all your inputs are perfect, the wind will still be variable, so it depends.
Yaw will effect your CdA so don't expect to get the same value if yaw changes significantly.
Re: Calculate you CdA... wind is ok. [rruff] [ In reply to ]
This is really good. You can use macros to invoke the goal-seek function instead of doing iterations.
Re: Calculate you CdA... wind is ok. [Jamaican] [ In reply to ]
Thanks.
I'm a hack when it comes to Excel... I'll look into that.
Have you used it? I noticed you raced recently... you can use it on different sections of your race file and see how it comes out.
Re: Calculate you CdA... wind is ok. [jackmott] [ In reply to ]
Sounds cool...
I have a similar worksheet that I've been using for myself that actually goes one step further I think. It takes as input your second by second power meter data INCLUDING latitude and longitude at every point on the course. It then infers your heading at every point from the lat/long data. You enter in a CdA and Crr and also wind heading and wind speed, and then it computes and graphs virtual elevation and GPS altitude. You can also use solver to find the best four values matching up VE to your GPS altitude (which I realize is not always great but it's the only way to automate it that I know of).
Around here virtually every time trial has lots of wind, and many courses are not simply out and back so I find it helpful to adjust for wind. Of course the worksheet requires a consistent wind to work well. If you're on a mountain course where winds tend to swirl and change direction from one point to another it doesn't work that well.
If people are interested I can clean it up a hair for public consumption and then post it here as well.
Re: Calculate you CdA... wind is ok. [lanierb] [ In reply to ]
I did a little thing a few years ago where I tried something sort of like that. I was looking for a "virtual wind" that would minimize the overall difference between VE and measured altitude given the constraint that wind was constant in direction and speed. In the end I decided that the constraint was a tad too constraining for "real world" courses so when AndyF suggesting building a sensor to measure windspeed and yaw on the bike rather than inferring it from positional data that seemed the way to go. But I think if you *can* make the assumption of constant speed and direction you can actually do not a bad job. In my original field tests I was using a triangular course so the direction of the wind was pretty predictable and I got results that were in the right ballpark.
Re: Calculate you CdA... wind is ok. [RChung] [ In reply to ]
Yeah I've had quite a bit of experience with it over the last year and it works really well sometimes and then not well at other times. If you're on a flat open course with constant wind it makes it possible to do VE at times when you otherwise couldn't have gotten a reasonable number out of it. However, it often doesn't work very well for the course near my house, for example, which follows the foot of a row of mountains (foothills really) with the turnaround being near a pass where the wind blasts through the mountains and thus changes direction. Another problem I run into is CdA changing with yaw angle. The biggest issue is when I run a disc in races. At some points on the course the crosswind is just right to stall the disc and the worksheet has no real way of accounting for this. I would say it's rare that the wind would be so consistent that you could get the kind of accuracy that you and AndyF are looking for. But, it does make it possible to ball-park CdA after a windy race, and especially one that is not a straightforward out and back, which I find helpful.
You know, one of the things I've kind of noticed (that is, it appears to be so with the limited sample size I've collected) is that either the estimated CdA seems to be in the right ballpark or it's complete BS. The BS estimates come when the wind is clearly gusty or the course has a mix of wind features. I suppose if I were more systematic I could get a sense of how gusty I can still get away with on the test venues I use though that requires a greater degree of desperation than I normally possess. Anyway, I was going to say that this is kind of encouraging: either you're in the right ballpark or else you're so far off you don't get fooled thinking you're in the right ballpark.
That would be great... but IME the GPS altitude is way too variable to be used on the fly.
On the other hand, if you could map the elevation on a segment using *accurate* elevation data, that would give you something to synch to using VE.
Actually you could do coast-down measurements on a flat road in both directions.... wouldn't even need a PM then.
Really not possible if the wind shifts. That's why it is important to take multiple samples (laps)... but if you were lucky and the wind was constant you can get a good number.
If you have "measured altitude" you should be able to remove the constraint of constant wind... ie VW is the variable you solve for. I thought about doing that a long time ago (right after you presented VE actually), but interest was never able to overcome my inherent laziness. There are some perplexing details if you want good accuracy... like keeping your data synched up with the mapped course profile (because you can't measure it accurately on the fly), and what factors to use for CdA vs yaw... plus you *do* need to figure out how to convert your VW values into both a wind direction and intensity to get yaw in the first place.
Do you have or know of a good resource that breaks out optimal to acceptable to poor CdA for a triathlon setup? The resources I have found show somewhere around .23 to be optimal but not sure what the ranges look like.
Re: Calculate you CdA... wind is ok. [songmak] [ In reply to ]
Why would your resources say .23 is optimal?
If you don't have constant (or constrained) wind then you have an underidentified system of equations.
I created an feature to Suunto Ambit, that also calculates CdA on the fly when riding. Idea was that you could try different positions/hand placing/head position in real time. No need to wait until you get home.
Haven't yet properly been able to test & adjust the calculation..
http://www.movescount.com/...app10000009-AeroDrag
Your "optimal" CdA will vary depending on a lot of factors... like your height and weight, body shape, length of your races, the equipment you are using, and how well you can adapt to a low and narrow position without losing significant power.
Based on what I've seen on ST, a lot of average sized people are >.30 even with good equipment. I'll take WAG and say ~.28 is probably average... but only because most don't really work on their position. <.20 has been achieved by a few... and I'd guess <.25 is possible for just about anyone with a little work, without needing to buy the fanciest stuff.
Just adding a link to my worksheet as well in case anyone is interested:
https://www.dropbox.com/s/cqgry09fmw6wb30/VE_with_Wind_Dunlap_2012.xlsx
Note: this is from a race where I had a crappy position and also massively overheated so I don't want to hear about my crappy performance that day! The key detail is that the wind was blowing hard and it was a clockwise square lollipop course with the finish line being not quite all the way around the lollipop, so it would be really challenging to get a good CdA estimate due to the amount of wind, shape of the course, and an overall net headwind. Correcting for wind does a pretty good job though (where "pretty good" means there's still some noise). Just try setting wind speed to zero and see what happens.
Re: Calculate you CdA... wind is ok. [JanneK] [ In reply to ]
Nice idea, but you are going to get wild fluctuations in power to overcome grade and wind effects, that will swamp any positional changes you are making.
iBike has been selling a device for years that measures grade with an accelerometer, and wind speed as well, and they still have trouble with CdA on the fly.
Glad I stumbled upon this. Thanks for sharing, I will be in search of a 1mi. stretch this evening, I have a few in mind.
That's pretty cool... thanks for posting that.
Your GPS altitude looks a heck of a lot cleaner than what I see. Are you sure that is GPS and not an altimeter?
Also... do you have a Strava file up of that race?
Re: Calculate you CdA... wind is ok. [djinc] [ In reply to ]
Just a reminder... you need to do all your accelerating before you get to the test segment... and IME that takes ~1/4 mile even if I sprint fairly hard to get going.
rruff wrote:
... a lot of average sized people are >.30 even with good equipment. I'll take WAG and say ~.28 is probably average... but only because most don't really work on their position. <.20 has been achieved by a few... and I'd guess <.25 is possible for just about anyone with a little work, without needing to buy the fanciest stuff.
That agrees with what I've seen. In wind the wind tunnel and aero field testing sessions I've participated in across about a dozen riders ranging from approximately 5'7" to 6'2" tall and between 65 and 80 kgs in weight CdA has varied from an ultra slippery 0.21 up to 0.27 but there's a lot of sample bias here as each of these riders had an interest in improving their aerodynamics or they wouldn't have participated in these sessions. So 0.28 as a rough swag of ST positions, especially with a lot of folks targeting longer events seems about right and no doubt some of the upright positions we see posted here aren't quite that good.
In terms of the folks (mostly TT riders targeting shorter events) I've worked directly with in the field who started with decent shop fits 0.25 or thereabouts seems to be a pretty typical starting point but they were all able to improve on that at least a bit with some work. IOW, I also agree that getting below 0.25 is a reasonable goal for most folks at least for shorter events but may be more challenging for folks that can't ride most of their event with their head deeply turtled or with an aggressively low front end that can challenge comfort and up the road vision.
In terms of optimal, I think about 0.1 is pretty optimal assuming I could still sustain typical power too bad my bike without me aboard likely comes in above that ;)
Realistically optimal is going to depend on all the things others have mentioned but if you can get much below 0.25 and do that while staying reasonably comfortable and are still able to sustain solid power for the duration of your events then you're doing pretty well. If you can do all that and get below .22 or so then you're in the super slippery class and if you're up around .30 or higher in your current position then you probably want to work on that position to try to eliminate any limiters that are keeping you from getting more aerodynamic.
-Dave
Ah, very nice. I've never done the Dunlap TT course -- is it uniformly exposed to the wind? I presume it's as flat as everything else in that area.
It's basically flat, pretty far inland and surrounded by open farm fields, so it seems like the wind is pretty consistent (consistently brutal that is). I did it again this year and same thing basically.
