Quote:
I've looked at those studies a bunch and it's not clear to me that the joint torques calculated by that model are correct since it appears that the model only considers a single leg...i.e. it doesn't take into account the fact that pedaling is done with a system of 2 legs coupled by the cranks.
You would know better than me! I think it is still be worth testing, at least once though.
Quote:
I've found that a LeMond Revolution trainer has enough inertia to observe the "non-round ring on an SRM/Quarq inflation factor" ;-)
The "inflation factor" is also readily apparent riding outside with a PT wheel to compare it to...
Unfortunately I have no access to either of these. Sounds like I have no accurate means of testing. So instead I'll have to rely on my gut combined with less than ideal testing. If you have any ideas for semi-accurate methods, given the following long list of things I don't have access to that would be great: velodrome, hills longer than 3 minutes to climb (which really sucks since I excel at climbing), powertap (or power meter for that matter), lemond revolution. I do have a trainer, rollers with a resistance unit, and might be able to get access to a computrainer. Might have been easier to list things I do have access to haha.
I know you had done testing with osymetric rings to show the inflation factor, have you done any testing to see if they actually work as advertised beyond that?
Jordan Oroshiba --- Roadie invading Triathlete space for knowledge access
