Omega on the rear of an S5
I finally had a chance to play around with getting an Omega on the rear of my S5. Here's what it took:
  1. An M5x14 button head SS screw (this needs to be tightened with a ball end hex key. edit: before the cable stop is mounted to the brake)
  2. 2 large and 2 small spacers (as supplied with the brakes...luckily I only needed one small spacer for the front so I could use the thick spacer from that brake)
  3. A slightly shorter brake mounting nut (the nut supplied with the brake is just barely too long...it bottoms on the washers before tightening with the S5s mounting plate).
  4. A plastic cable end ferrule that I could trim short
  5. Some creative filing on the backside of the cable stop plate.
Oh...and it appears the brake arms have a bit of "toe-in" built in (tapered part of arms slightly inboard), which works great in the front brake position, but I found out that it leads to horrible squealing under heavy braking when the brake is mounted on the rear due to the "stick/slip" that happens when pads are angled the wrong way. Not wanting to "shave" the pads, I decided to put a couple of plastic shims in between the pad holder and the brake arm in front of the mounting screw to accomplish the proper toe-in on the rear. There was enough "slop" to angle them just right when I tightened pad holder mounting screws. Squealing gone :-)
Re: Omega on the rear of an S5 [Tom A.] [ In reply to ]
Do you have one on the front too? Can you post pics of that? I am thinking of doing the same on my S3.
ishi no ue ni san nen | Perseverance will win in the end. | Blog | @nebmot | Strava | Instagram |
I get it, I do. I love it...but what did that gain you over this?
Re: Omega on the rear of an S5 [Record10Carbon] [ In reply to ]
Re: Omega on the rear of an S5 [jackmott] [ In reply to ]
Bullshit. I dont buy that for a second. We were breaking the hour in the 40k long before the Scott DH, let alone all this gibberish.
Again, I love it, I love the looks and I love tinkering. But three seconds? I hope there is a flux capacitor under the cover.
Compare the green line to the blue:
http://upload.wikimedia.org/...nthourrecord.svg.png
So, you are saying that that caliper on its own will save a person 3 seconds over the Record caliper?
It is a guess, up front it saves about 6 per Andy Coggan's wind tunnel test.
the rear will be less.
Thanks - my issue that I did not point out was that it was the rear...up front, I really really get it. I for one damn near never use my rear brake (thus Campy also agrees and has had a single pivot for years).
jackmott wrote:
3 seconds per 40k!
Says who? They haven't put anything out yet. Is the 3/40k for the rear brake, or total with both?
Re: Omega on the rear of an S5 [Quel] [ In reply to ]
Quel wrote:
jackmott wrote:
3 seconds per 40k!
~6 for 40k for the front brake.
this based on following andy coggan's teaser posts.
Would you really run these on a road bike in a crit/road race? Ugh.
I have an Omega on the front of my P3-SL and it is great, but the modulation/stopping power is awful compared with any other top tiered brake (Red/Force, DA/Ultegra, etc.). I'd likely LOSE time/watts in a pack/cornering than in drag savings. Love the design though.
Carry on if the S5 is your TT rig.
Fatigue is biochemical, not biomechanical.
- Andrew Coggan, PhD
Re: Omega on the rear of an S5 [rroof] [ In reply to ]
And the past comes back to haunt us....
But you rarely need to hit your brakes if you are cornering fast! =)
I would think it more of a safety concern than a cornering disadvantage, but maybe with a big STI lever it isn't so bad.
actually running it on the rear but NOT the front for a road bike might be perfectly reasonable.
But why? Why when the options from Shimano, Campy and SRAM are so damn good?
3 seconds!
Um.......again.......did the rider take a dump (at the proper angle, that is 10lbs right?) right before the ride? Did he or she also trim their helmet straps?
Both dump and non dump riders will save the 3 seconds.
Re: Omega on the rear of an S5 [nebmot] [ In reply to ]
Here you go, although I technically haven't finished the front (my under stem cable stop is being shipped as we speak):
jackmott wrote:
3 seconds!
Right ... think a little more clearly about ALL aspects of bike racing ...
I'll go admire my jersey I took home 2 days ago in my state road race without an aero brake (again, I left it on my TT bike where I managed only a silver) ;-)
Sure, I realize that a rear aero brake caliper by itself will likely never affect your placing in a road race.
But, you need a brake back there, and you don't really ever need to use it, so it might as well save you a couple grams of drag, eh?
*hitting head against the wall*
I need a front wheel too, but I'm not running a front disc ... or a rear disc for that matter for a road race.
There you go, getting your abilities and the fact that 95% + of the aero problem is the rider in the way.
A front disc would be dangerous.
An omega rear isn't.
As for the rear disc, I would do it if not for peer pressure. Its actually safer, no skewers or derailleurs going into your spokes!
Nice work, Tom!
I have two questions:
1) Are you concerned at all that the filing on the rear cable holder will weaken that piece?
2) What advantage does the Omega have over the Egg? Aero (besides the possible naked cable)? Leverage? Better modulation? Easier to adjust?
Cheers.
-Mike
"100% of the people who confuse correlation and causation end up dying."
