Hi Tucker 1050, I had a grade 4 AC separation in Feb 2011 after getting run over by a "gorrila" outside my goal crease playing hockey. The surgeon carried out surgery in March 2011 and I had a screw inserted to keep the joint in place while it healed and two pins that were placed parallel to the shoulder and were situated on each side of the screw to keep that in alignment! The pins were removed (thankfully) 2 weeks later (just hand removed no local etc). I was told the screw would be removed after 8 - 12 weeks via a local freezing and incision - everything I read on line also gave this time frame for removal.
As to your question - the surgery did a 100% job as to leaving no "bump on my shoulder" and my therapy went very well and as instructed to do so. However, for whatever reason the surgeon said after my 12 week visit the screw was to remain in place for up to 1 year! Couldn't figure that out at all. Anyway, as I continued my therapy and gaining my range back I could feel a kind of restriction and a rubbing of sorts at the area of the incision. I also experienced some kind of "locking - up" at that point whenever I brought my arm back to a resting position after raising it etc and to me it seemd obvious the screw was hindering my progression as to therapy and further movement since it felt like I had hit a wall as to further extension of my arm and therapy. I was told by the surgeon this was not the case.
In late summer of 2011 I requested the screw be removed and again in October 2011 the same request and asked why they did not take x-rays at that time to see if anything had changed - I was told it was not necessary! My next appointment was not slated until the spring of 2012 but of late I had enough of the feelings inside my shoulder as mentioned previously and went to see the surgeon at the fracture clinic of the local hospital (he sees patients there in the afternoons) on Dec 5, 2011 and pretty well told them I want an x-ray and an appointment NOW! They managed to fit me in - took the x-rays and I saw the surgeon who said - " I don't like what I am seeing here on the x-rays" - duh! It was obvious the screw was not broken but the screw and washer had worn into the bone about 1/3 of the way or more - showed as a dark hollow spot on the x-ray and you could clearly see the screw and washer below the the surrounding surface of the bone it was holding in place. Obviously in my mind this was a result of the movement of the screw and washer during my everyday movements and therapy sessions - despite being told this was not happening. The only answer from the surgeon was it was not unusual to see and now general anesthetic and surgery again to remove the screw and washer (no local anesthetic surgery now since this has happend) and I guess time to fill back over the void/hollow spot now there in the bone.
Pretty long winded response to your post (sorry about that just wanted you to have the history on this). If I had to do it over again and having a buddy who did not have the surgery and seeing his restrictions (and the cosmetic results - huge bump) I would still definately go through with the surgery, however knowing what I know now I would insist on the screw removal after the max 12 weeks that I have read up on. Having this screw and washer in place for the almost 9 months now I fear has created a whole new issue for me. I am convinced however that once this is removed (week of the 19th Dec 2011) I will finally be rid of this "rubbing, locking up and wearing situation" that I was feeling daily for the last couple of months and finally get to where I should have been months ago.
I am really annoyed at having no real answers as to why the fixture (screw & washer) were left in for so long and it bothers me to have the doc telling me the feeling inside as to rubbing, restrictions etc can't be the screw but rather just the "healing process". Who knows what your feeling inside your body more than the person living with it! This whole thing just does not sit right with me at all. If anyone has had similar issues it would be great to hear from you - thanks for reading and best of luck to you Tucker 1050 (David) regardless of the choice you make.
