In Reply To:
pls explain the large difference in cost that still exists when they both offer Powertap Discs? i.e. stinger PT disc versus sub 9 PT disc? I have had 2 zipp discs- a dimpled one and the model before that- with their wonderful hubs- and both were not as true as my old standard HED disc (no longer made)- OR my powertap JET disc- that is dead on true and light. Also- the JET PT bump disc DOES fit in my P3.
PLUS the JET PT disc is MUCH stiffer laterally than both the zipp discs and the old style HED disc (which they no longer make).
That's actually pretty easy. HED's PT discs are spoked PT wheels with a carbon cover over them. That's a relatively easy process to do. Zipp molds their hubs into their discs, which means they had to make a custom hub that housed the PowerTap torque tube & electronics. So HED's PT discs have a PT hub at the core, which is a decent or pretty good (depending on whether you have the newer or older style axle) Taiwanese made hub. Zipp's PT discs have the exact same Zipp internals as their other discs (there is absolutely zero difference in the mechanical workings) but they incorporated PowerTap's electronics. Zipp designed this whole hub from the scratch, since mating their mechanicals to the PT electronics was obviously not straightforward. But at the end of the day, you get the exact same hub quality as you'd get if you had bought a regular hub.
I have four Zipp discs. Each one of them is perfectly true. I've seen a ton more, and I've yet to see a disc that is not true, but that is simply my experience with Zipp wheels, not a statement of universality. In all cases, I'm sure everyone has horror stories about HED, but not Zipp. And somebody else has had a terrible experience with Zipp wheels, but not HED. I only have my own experience and that of people that I know to draw on. That's obviously not everyone in the world.
If the Jet PT bump disc fits your P3, a Zipp clincher disc likely would as well. The variance in terms of whether or not the disc will fit is related to the wrapping of the lug joints in the P3 where the rear triangle is attached to the seattube lug. The amount of carbon wrap and paint there is quite variable. That is why the same disc will fit on some P3s but not on others. It is a function of the frame, not of the wheel. The variance in Zipp's disc wheels is, IIRC, .004 of an inch, so it's not wheel variance that causes problems with the fit on the Cervelos. I am also not sure of the max width of the Jet bump as opposed to the 900 clincher bump as opposed to the Sub9 bump. If an 808 fits in the back of your p3, a 900 clincher disc will as well.
As for lateral stiffness, is that your opinion or is that from something published?
