fegirl1 -
Thanks for the post! We have discovered an easier method of pulling on the neoprene sleeve. I will detail in writting and supply a picture later today.
The process should take about 10-30 seconds.
Let us know if you are still having difficulties.
I will get some pics up shortly.
thanks!
Speedfil
- Locate some brake or derailleur cable or sutiable string that can handle a fair amount of tension.
- Use the speedfil supplied thumb screw and nut and crimp one end of the cable onto the thumb screw and secure it with the nut.
- Slide the cable through the tubing so that you have at least 24" of cable exposed.
- slide the neoprene sleeve onto the cable portion only.
- Using a vice or close a door onto the cable secure the cable at one end. (Your setup should now look like cable attached at one fixed end, sleeve on top of cable, tubing, thumb screw/nut as a stopper on the end).
- Lubricate the tubing with water, pam, cooking oil etc.
- Pull on the tubing to create tension on the cable/tubing.
- With either your hands or a set of pliers carefully grab the wire inset on the sleeve and pull firmly but gently the sleeve onto the tubing.
- Work the sleeve about halfway down and then use your hands exclusively the remainder of the way.
- Be sure to keep the wire insert from poking through.
thanks!
Speedfil
