The data out there making people favor their Xentis wheels was produced by Triathlon magazine in Germany. They did indoor velodrome testing showing that a pair of xentis MK1 on a P3 using an SRM was 3 watts faster than an 404, the next year they went back and did the same test using lots of different wheels. That year the Vuelta Carbon Pro (old 404 rim but with 12 spokes) won the test at -38 watts from baseline with Xentis at -37 watts, 808 at -36 watts and 999 at -29 watts, interestingly the Corima disc/3 spoke came in at -22 watts, Lightweight -27 watts with the Ritchey Carbon (404 rim) and Easton Carbon (404) rim being -28 and -29 watts respectively.
The problem with these tests is that they were done at zero yaw. The press in Germany really treated this as a breakthrough, claiming that discs are actually slower than spoked wheels or composite spoked wheels. The problem is that nobody took into consideration that the test was done on an indoor velodrome. This concept is something we've been trying with no success to sell to the US track program, that at 0-2 or 3 degrees of yaw, the skin friction of the disc makes for higher drag than a good aero wheel, but past 2-3 degrees of yaw, the disc dominates most anything. If you look at the Tour magazine data or any of the zipp published data, you see that this is not some revelation, but exactly what the data has been predicting for years, and for road and tri use this is a non-issue as 0 degree or near 0 degree wind angle is so unbelievably improbable, even on an indoor track a shorter or higher banked track will induce larger effective crosswind angles due to rider lean and stirring of the air by other riders and so on, but in this case they were testing at a rather large/shallow indoor track and actually managed to replicate almost exactly a lot of the low yaw wind tunnel data we have taken over the years. The problem of course is that this was published in a triathlon magazine and not a track racing magazine...
If you look at the Tour magazine data from 2005, you see this predicted almost exactly, they are showing the 808 and xentis both having slightly lower drag than the disc at zero yaw with the xentis ever so slightly winning, but get to 5 degrees and it is not contest anymore and at 10 degree the difference between the disc/808 which are almost identical and the xentis is about 80 grams of drag or roughly 10-11 watts additional to maintain the same speed.
Bottom line is that some creative rim shaping makes a wheel like the 808 faster than a dis at around 0-4 degrees of yaw and again at 8-12 degrees of yaw (as verified in both Zipp and Tour mag data within grams of each other) but past that, the disc kills everything. Cees is right that there is some increase in tire rolling resistance due to increased side loading, but the side loading of the disc at say 20 degrees is about 3800 grams which is considered minor compared to the 40000 grams of vertical load the tire would see with an 80kg bike rider system with 50/50 weight distribution, although nobody has a good way of measuring this, however, at say 20 grams of drag a disc has more than a 100 gram drag advantage over any other wheel, so it would take a lot of RR to offset the gains.
As for covers, the BikeTechReview data has been discussed by a lot of people I know in the industry and there are a few things to be aware of, first the disc used was borrowed from somebody, it is a 1992-1992 Zipp 19mm wide disc with 20mm braking zone that was ground parallel, this is an old technology that was replaced years ago as the lip between the body and brake surface causes considerable drag...construction similar to this is still used by quite a few manufacturers, but is really not ideal. Also, the tire on the wheel was quite used and not the same tire used in the other testing, and was from my understanding rather used as this wheel belonged to somebody. As a result, the data for the real disc is far worse than anything anybody else from Tour magazine to us to John Cobb has ever recreated for even a similar disc much less a modern one, so in that way I think the comparison between the two wheels is a bit misleading in that particular test. Also, the disc cover wheel used was a very meticulously constructed and maintained wheel with very nicely sealed edges and no apparent blend problems between rim and skin. This test does show that a cover can make for a very efficient wheel, but having said that, there are two issues people always overlook with covers. First, a cover is not lenticular, it is conical, not that is affects the data too much, but the conical wheel tends to have both more surface area and more frontal area than a lens or flat disc, so at lower yaw angles the performance suffers. At higher angles the wheel performance is entirely dependant on the care taken in assembly, as I said with the original Zipp disc construction and the construction of most clincher and even some modern tuby discs, a 0.030" (0.75mm) step at the skin/rim interface will cost you 6 watts or possibly more. So while a cover can be made quite fast my experience is that almost all of the ones I see in IM pits and such are not constructed or maintainted to their potential. As someone who used to use and manufacture covers before I worked for Zipp I can tell you that I used to spend hours before every event tweaking and maintaining the thing to get it just right, the best is to permanently silicone bead the one half to the rim using C clamps and wood blocks to get the surfaces exactly flush...the other side really should have a valve hole cut in it and do the same for it's asembly as taking the thing on/off can really throw the alignment out and create discontinuous surfaces, I had a coach that drilled all of this into us as juniors without any data, but I can now say after having spent hundreds of hours in the wind tunnel that he was spot on.
http://www.SILCA.cc Check out my podcast, inside stories from more than 20 years of product and tech innovation from inside the Pro Peloton and Pro Triathlon worlds!
