I swim in a 25m pool, rather than 25y. That's about 10% extra. (just to clarify that)
I'm a lazy, old, fat,
b@stard. I don't want to do any more work than I have to in the pool.
Therefore, I have focussed primarily on efficiency. That means two things mainly.
1) Body Position. No use flinging your arms around if you swim with your legs and butt hangin' down, increasng your frontal area. Get your legs and butt right near the surface and your life will be sooooo much easier. Body position is critical and the numer one thing I focus on
2) Long boats go faster than short boats (assuming the same width etc) so I make myself as long as possible. For example, I put my hand out front and leave it there until my other hand pretty much enters the water beside my head. That way I'm longer, for longer, so to speak. Many people start their pull right away, resulting in being shorter on average. And that means slower. Another trick to make each stroke last longer is to make sure you brush your thigh, as close to your knee as possible, to maximize the length of your stroke. You don't actually et much power at athe back end of your stroke, but it does keep you long for longer, hence efficiency improvements, lower stroke rate and fater over long distances.
I practice catchup drills alot and for a 46 year old 5'7" fat guy, I go pretty fast. (not fast overall, but fast for the conditions noted above). When I get tired, say at the end of a 1500m set, I concentrate on long strong strokes, rather than just trying to flail my arms faster.
TriDork
"Happiness is a myth. All you can hope for is to get laid once in a while, drunk once in a while and to eat chocolate every day"
