It categorically will not fit. I tried it on my wife's B10.
The issue is not the chain stay, it is the adjustment on the rear brake. It fouls the Stages mount by around 3mm. It clears the frame easily.
I sourced a DuraAce 7800 rear brake which is a lower profile but you have to mount the brake a little off centre and even then there is only about 1mm or less clearance. On climbing it still rubbed, and my wife is only 95lbs so not exactly pushing the power out.
The solution would appear to be a TRP T925 rear brake. I ordered one and it is sitting on the table next to me as I type. I spoke with Dave from Felt (SuperDave on this forum) and he recommended this one. It looks like it should work perfectly as it dispenses with the brake adjustment arm reducing the profile buy quite a chunk, I will post pics once it is installed.
Hope that helps.
The Stages works well by the way, she swapped the crank arm over to her roadie (I got her Felt a new crank to match the roadie for that reason, so she could swap between them). She loves it :)
https://www.pbandjcoaching.com https://www.thisbigroadtrip.com
