I just put on a new tire on my front wheel and was distressed to learn that it is slowly leaking at a much faster rate than the rear one, which has the same type of tire glued to it. I have to use valve extenders for the Hed Jet/Deep rims and know that there will be some air loss of over time, but this is excessive. After about 8 hours it has gone from about 120psi to maybe 40psi.
These are the first set of tubulars I've owned and I'm feel a bit frustrated. I have followed Dan's recommendations about gluing them on and it all seems good until I come back to the wheel a few hours later. The first tire I glued on this front rim developed a leak around the valve stem that dropped air immediately. I looked around the valve hole and didn't see any problems with the rim that could be causing this.
Any ideas what might be going on?
Thanks in Advance.
Thanks in Advance.
