This is probably an easy question, but I am trying out WKO 4 on the trial to see if I can use it for coaching myself. I did the 20 minute FTP test suggested in TARWAPM verbatim (I always do the same test). I came up with 333 watts for the 20 minute effort, so I set my FTP in WKO 4 as 316. My mFTP went from 306 to 308, however. My TTE is also apparently 33:37. The 5 minute blowout effort was at 374 watts (also a personal power best for that duration). I calibrated my power meter before both tests and I think the results are valid based off recent training and racing data.
Here's my current thinking, which I'm sure is wrong so please correct me as I'd like to learn. TTE and mFTP say I can do 308 for 33:37, but my test suggests I should be able to do 316 for about an hour. On a very good day and under optimal conditions, I believe the 316 would be possible for about an hour. The 308 would be more than doable for an hour, likely a bit longer. Due to the nature of road racing and the fact that I don't test at 60 minutes (hard to find a long enough stretch of road), my 60 minute power is objectively lower than 5 and 20 minutes (because those are where the concentration of efforts happen to be). So is this what is dragging down my mFTP?
My main question is: shouldn't my mFTP be higher than my sFTP?
