Slowman wrote:
"narrow is aero for racing"
what i keep seeing, tho, is rims getting wider, and wider, and wider. and the tire to follow suit, as long as the tire is not wider than the rim.
or is that not the modern thinking?
Modern, but often misguided.
1. Yaw angles are generally <10 deg;
2. the most aero tires/wheels at low yaw angles are generally narrow, not wide (by modern standards);
3. Rolling resistance needs to be considered as well, but there are some narrow tires that roll really well.
The above leads me to chose older, not especially wide wheels, with relatively narrow (by current thinking) tires (e.g., ~20 mm by direct measurement).
