Most people in here are quite correct about lots of this stuff. From my end, this is what I'm seeing -
1. Don't have the time to train (and not interested in anymore) out slogging mega-hours. I've got a kid and job that needs me more than that. Wish it was different, but it's not.
2. I certainly have hopped around from one method to another, which undercuts growth.
3. I do overbike for sure. So I under-biked this weekend and started out with a decent run speed (for me) at the start. That was a nice change. Started getting sick about halfway through the run, though. Not sure what caused that. I hardly ate anything but drank plenty of water on the run up until then. Any input would be great. 4. I talk too much for sure. Working on that, but that takes time to change a personality.
5. Correct on the 50 milers not being great bike-run stuff. They are very related, but not quite enough to be equivalent. I'm considering skipping the ultra running this winter to work on run speed instead. I am appreciative of the ultras though - they turned me into a much better runner than I ever had been before.
6. I've been biking with power for nearly 10 years and can tell when my numbers change even the tiniest bit. After a point, tests just confirm what you already know. If you monitor your workouts, you can easily spot and where your FTP is. If I did an hour at 273 last fall and all my workout numbers are the same or better, an FTP of 273 is still a safe bet.
Thanks for the input!
Zen and the Art of Triathlon.
Strava Workout Log Interviews with Chris McCormack, Helle Frederikson, Angela Naeth, and many more.
http://www.zentriathlon.com
