exxxviii wrote:
I am a late adopter for tubeless. I had always assumed that you just carried a spare tube in case of a flat and temporarily converted back to tubes in the case of a flat. I am this many days old when I learned that plugs for tubeless exist.
So, what is the best product and why: Dynaplugs, Stan's Darts, KOM repair kit, something else? And would plugs alone be sufficient, or should I also plan to carry a tube for a worst case situation? (Dynaplugs seem excessively expensive when there are many $20 options out there.)
Yes, you can certainly remove the tubeless valve stem from the wheel and replace with a tube if you are not running a tire insert. I suppose you can if you're running an insert as well, however, that needs to be removed from the tire and carried to make room for the tube. Absolutely no issue doing this other than it's a slower repair (but no slower than replacing a tube on a traditional tubed tire).
Tire plugs are often a fix that takes a couple of seconds. Pull over, take plug out of repair kit, shove into hole, add some air, ride away.
I prefer the Stan's Darts and Dynaplugs for 1 specific reason: they both have a "barb" like system that can be inserted into the tire but resists being pushed back out with air pressure. The traditional bacon strips can be twisted in such a manner that they wad up inside the tire but this is less reliable and I find that pressure can cause them to leak / pop out.
I talk a lot - Give it a listen:
http://www.fasttalklabs.com/category/fast-talk I also give Training Advice via
http://www.ForeverEndurance.com The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
