For reference only - here is the strap part of the 310xt set up http://www.trademe.co.nz/...ng.aspx?id=462896268 Trade Me is the equivalent of eBay in New Zealand. The reason it is/was for sale is/was because I had the watch ripped off my wrist in the middle of a sprint tri.
The Quick Release Kit Part Number 010-11215 requires the re-use of the straps that came with the watch (Garmin provide a tool to extract the pins)
What is not made apparent is that Quarter turn Bike mounts - part number 010-11430-00 are compatible with the 310xt (and vise versa) but I seem to
remember that when I tried the Edge 500 on my strap, it was turned through 90 degrees.
I have since moved onto the 910xt again with the quick release strap but in this instance, the Kit comes with additional straps - you re-use the pins
The difference between mounting plate is that the 310xt mount is flat where-as the 910xt is curved, and although I cannot test it (because the 310 is at the bottom of a lake) a 310xt should fit on a 910xt strap, but the 910xt definitely does not fit on a 310xt mount.
What this actually means (now that I think about it) is that the release kit for the 910xt is probably better because you get the straps included and they are black
If anyone needs photos, just ask
