EDIT: I am going to strip the Cervelo P2C down to bare carbon but do not want to spend hours upon hours doing this. Is there alternatives to stripping a carbon frame other than sanding and/or scraping it with a razor blade an than sanding.
Just purchased an older Cervelo P2 and wanted to know if anyone has stripped a P2 frame. I will most likely use the razor blade removal system which seems to be the best option from what I have read in several forums. Just wanted to know if anyone has done a P2 and how long roughly it has taken to remove the paint using this method.
Also curious to others who have stripped a Cervelo how much filler they encountered when stripping the frame down. I know on my SLC there was a fair bit around the tube joints so that was the reason that I left the main part of the tubes exposed but painted the joint. Not sure if I will do the same on this frame or go completely nude.
